Surface Pro 4, Screen Flickering, Shaking
2017-01-19T07:47:47+00:00
Hi All,
Update: Flickergate is now having a forum to bring all affected users at a single platform to plan for resolvement of issue. Please join at
 https://forum.flickergate.com
UPDATE: Check FlickerGate.com for videos of the problem and to submit your own.
I purchased SP4 device a few months ago and it was working fine for a month. Then I noticed that when the CPU is at its max, the screen flickers a bit. Investigating further revealed that it flickers even if it is setting idle. It does not flicker if at least one of the following thing is done:
  1. A video being played in browser
  2. If I keep the touch screen busy by either taping it or keeping a finger on it
  3. If I use the touchpad
  4. If keyboard is used for typing
This resulted in making the device completely unusable while reading articles or ebooks. I am a developer, most of the time I have to read the code and to do that, I have to constantly keep a finger on the touch pad or the screen. I contacted surface support in October and November and was told that the developers are working on the patch. Looking at the updates the developers are pushing since then, I don't think anyone is even aware of the problem there.
My previous support ticket numbers are:
 ***deleted personally identifiable information***
Just wondering if anyone else had the same problem (and the fix) and if not, what's the procedure for the refund? I will rather go for a mac then sacrificing $2000+ for a dancing screen.
Kind Regards,
Abbas
2018-05-11T17:59:00+00:00
Hey Everyone,
Creating the best products and experiences for our customers is our top priority.
We have heard your feedback and after careful examination, have determined that a small percentage of Surface Pro 4 devices are exhibiting a screen flicker that cannot be addressed with a firmware or driver update.
To support customers affected by this issue, we will replace eligible Surface Pro 4 devices for up to three years from the date of purchase, free of charge. If you believe your device is experiencing this issue, please visit our Surface Pro 4 screen flicker article for more details.
Bryan [MSFT]
2,779 additional answers
    2018-04-11T06:54:49+00:00
    My SP4 still flickers even when I do all those three activities above. Sometimes they stopped flickering for a 10 minutes or so, but the display still have thin white lines so that's still disturbing.
    2018-04-11T08:57:25+00:00
    Sorry to hear that. Quite embarrassing Microsoft. List keeps growing and growing, and you stay quiet. Are you ever going to acknowledge the problem and make it right for us?
    Agreed. Lack of response from MS is really disappointing
    2018-04-11T21:22:07+00:00
    Has anyone had their screen replaced by a third party repair shop? And if so, has that permanently solved the problem? I want to get mine replaced, but I'm not sure if it will come back, even with a new screen. Thanks!
    2018-04-11T21:40:16+00:00
    I bought one from aliexpress ($110+), go it replaced ($40), worked for an hour or so, then went right back to FLICKERING.
    now some say it's the screen type is bad, but I'm fed up and going to buy an iPad Pro. let this be a reminder for when I even think about trusting **** companies like ****
