Surface Pro 4, Screen Flickering, Shaking
2017-01-19T07:47:47+00:00
Hi All,
Update: Flickergate is now having a forum to bring all affected users at a single platform to plan for resolvement of issue. Please join at
 https://forum.flickergate.com
UPDATE: Check FlickerGate.com for videos of the problem and to submit your own.
I purchased SP4 device a few months ago and it was working fine for a month. Then I noticed that when the CPU is at its max, the screen flickers a bit. Investigating further revealed that it flickers even if it is setting idle. It does not flicker if at least one of the following thing is done:
  1. A video being played in browser
  2. If I keep the touch screen busy by either taping it or keeping a finger on it
  3. If I use the touchpad
  4. If keyboard is used for typing
This resulted in making the device completely unusable while reading articles or ebooks. I am a developer, most of the time I have to read the code and to do that, I have to constantly keep a finger on the touch pad or the screen. I contacted surface support in October and November and was told that the developers are working on the patch. Looking at the updates the developers are pushing since then, I don't think anyone is even aware of the problem there.
My previous support ticket numbers are:
 ***deleted personally identifiable information***
Just wondering if anyone else had the same problem (and the fix) and if not, what's the procedure for the refund? I will rather go for a mac then sacrificing $2000+ for a dancing screen.
Kind Regards,
Abbas
2018-05-11T17:59:00+00:00
Hey Everyone,
Creating the best products and experiences for our customers is our top priority.
We have heard your feedback and after careful examination, have determined that a small percentage of Surface Pro 4 devices are exhibiting a screen flicker that cannot be addressed with a firmware or driver update.
To support customers affected by this issue, we will replace eligible Surface Pro 4 devices for up to three years from the date of purchase, free of charge. If you believe your device is experiencing this issue, please visit our Surface Pro 4 screen flicker article for more details.
Bryan [MSFT]
2,779 additional answers
    2017-04-21T20:39:21+00:00
    I have the same issue. Seems heat related. Tried everything!
    Has Microsoft provided a fix yet?
    2017-04-21T20:50:43+00:00
    Not yet, so far, their suggestions are to update to the creators update and if that fails, they ask you to run the repair tool.
    Plenty of people (including me) have voiced their concerned that this does not fix the issue.
    2017-04-21T20:56:02+00:00
    Groan... Thanks Sheco. I have sent tweets asking for help to @surface and @surfacesupport but no response yet.
    Seems almost bizarre that Microsoft is not dealing with this issue.
    {Perhaps they've decided to junk the Surface brand?)
    2017-04-22T00:28:38+00:00
    For us to assist you, can you confirm the following information:
    • Have you tried to check for and install the update?
    • What troubleshooting steps have you tried so far to resolve the issue?
    • When and where did you purchase your Surface Pro 4?
    Regards.
