Surface Pro 4, Screen Flickering, Shaking
2017-01-19T07:47:47+00:00
Hi All,
Update: Flickergate is now having a forum to bring all affected users at a single platform to plan for resolvement of issue. Please join at
 https://forum.flickergate.com
UPDATE: Check FlickerGate.com for videos of the problem and to submit your own.
I purchased SP4 device a few months ago and it was working fine for a month. Then I noticed that when the CPU is at its max, the screen flickers a bit. Investigating further revealed that it flickers even if it is setting idle. It does not flicker if at least one of the following thing is done:
  1. A video being played in browser
  2. If I keep the touch screen busy by either taping it or keeping a finger on it
  3. If I use the touchpad
  4. If keyboard is used for typing
This resulted in making the device completely unusable while reading articles or ebooks. I am a developer, most of the time I have to read the code and to do that, I have to constantly keep a finger on the touch pad or the screen. I contacted surface support in October and November and was told that the developers are working on the patch. Looking at the updates the developers are pushing since then, I don't think anyone is even aware of the problem there.
My previous support ticket numbers are:
 ***deleted personally identifiable information***
Just wondering if anyone else had the same problem (and the fix) and if not, what's the procedure for the refund? I will rather go for a mac then sacrificing $2000+ for a dancing screen.
Kind Regards,
Abbas
2018-05-11T17:59:00+00:00
Hey Everyone,
Creating the best products and experiences for our customers is our top priority.
We have heard your feedback and after careful examination, have determined that a small percentage of Surface Pro 4 devices are exhibiting a screen flicker that cannot be addressed with a firmware or driver update.
To support customers affected by this issue, we will replace eligible Surface Pro 4 devices for up to three years from the date of purchase, free of charge. If you believe your device is experiencing this issue, please visit our Surface Pro 4 screen flicker article for more details.
Bryan [MSFT]
2,779 additional answers
    2017-04-21T08:19:25+00:00
    About a month after receiving my Surface 4, a small section of the display (approximately 1"x1.5") now flickers at times. The flickering section is in the upper right, and does not flicker during scrolling/changes. It starts to flicker about 2 seconds after the last touch action.
    Suggestions to solve? Thank you!
    2017-04-21T08:27:40+00:00
    2017-04-21T08:30:10+00:00
    About a month after receiving my Surface Pro 4, a small section of the display (approximately 1"x1.5") now flickers at times. The flickering section is in the upper right, and does not flicker during scrolling/changes. It starts to flicker about 2 seconds after the last touch action.
    Suggestions to solve???
    ***Subject edited for clarity by the moderator.***
    2017-04-21T20:38:02+00:00
    Like so many other people posting here, I have the same issue. Seems to be heat related. Is there a fix for this MIcrosoft?
