Surface Pro 4, Screen Flickering, Shaking
2017-01-19T07:47:47+00:00
Hi All,
Update: Flickergate is now having a forum to bring all affected users at a single platform to plan for resolvement of issue. Please join at
 https://forum.flickergate.com
UPDATE: Check FlickerGate.com for videos of the problem and to submit your own.
I purchased SP4 device a few months ago and it was working fine for a month. Then I noticed that when the CPU is at its max, the screen flickers a bit. Investigating further revealed that it flickers even if it is setting idle. It does not flicker if at least one of the following thing is done:
  1. A video being played in browser
  2. If I keep the touch screen busy by either taping it or keeping a finger on it
  3. If I use the touchpad
  4. If keyboard is used for typing
This resulted in making the device completely unusable while reading articles or ebooks. I am a developer, most of the time I have to read the code and to do that, I have to constantly keep a finger on the touch pad or the screen. I contacted surface support in October and November and was told that the developers are working on the patch. Looking at the updates the developers are pushing since then, I don't think anyone is even aware of the problem there.
My previous support ticket numbers are:
 ***deleted personally identifiable information***
Just wondering if anyone else had the same problem (and the fix) and if not, what's the procedure for the refund? I will rather go for a mac then sacrificing $2000+ for a dancing screen.
Kind Regards,
Abbas
2018-05-11T17:59:00+00:00
Hey Everyone,
Creating the best products and experiences for our customers is our top priority.
We have heard your feedback and after careful examination, have determined that a small percentage of Surface Pro 4 devices are exhibiting a screen flicker that cannot be addressed with a firmware or driver update.
To support customers affected by this issue, we will replace eligible Surface Pro 4 devices for up to three years from the date of purchase, free of charge. If you believe your device is experiencing this issue, please visit our Surface Pro 4 screen flicker article for more details.
Bryan [MSFT]
2,779 additional answers
    2018-02-20T22:48:52+00:00
    Same issue here! Not running any programs (only standard background processes). Wasn't using my computer for about an hour and when I got back I got this screen (also recorded it) after waking up my pc (it was not turned off, but in sleep mode). Not amused for such an expensive machine. First you fail me as a windows phone user, now this.... You make it very hard for me to stay a loyal Ms user.
    2018-02-21T16:41:50+00:00
    Same problem here... how many of us?
    2018-02-21T21:04:57+00:00
    I set the taskbar clock seconds ticking. It significantly reduces the problem once the clock is on the screen but the problem shows up again when I do a PPT presentation. I then downloaded one of the many animated cursors and that works with PPT if you set it to keep  the cursor displayed.
    All kludges but I can use the machine without thinking of going to the optometrist.
    Seconds display: http://www.thewindowsclub.com/display-seconds-in-taskbar-clock-windows
    Animated cursor: http://download.cnet.com/s/animated-cursors/ ... cautiously take a free one
    2018-02-21T21:44:25+00:00
    You have honestly saved my sanity. And my eyes. And my life.
    I downloaded some clock thing that shows the seconds (for Windows 10).
    THANK YOU!!!!!!!!!!!
