Surface Pro 4, Screen Flickering, Shaking
2017-01-19T07:47:47+00:00
Hi All,
Update: Flickergate is now having a forum to bring all affected users at a single platform to plan for resolvement of issue. Please join at
 https://forum.flickergate.com
UPDATE: Check FlickerGate.com for videos of the problem and to submit your own.
I purchased SP4 device a few months ago and it was working fine for a month. Then I noticed that when the CPU is at its max, the screen flickers a bit. Investigating further revealed that it flickers even if it is setting idle. It does not flicker if at least one of the following thing is done:
  1. A video being played in browser
  2. If I keep the touch screen busy by either taping it or keeping a finger on it
  3. If I use the touchpad
  4. If keyboard is used for typing
This resulted in making the device completely unusable while reading articles or ebooks. I am a developer, most of the time I have to read the code and to do that, I have to constantly keep a finger on the touch pad or the screen. I contacted surface support in October and November and was told that the developers are working on the patch. Looking at the updates the developers are pushing since then, I don't think anyone is even aware of the problem there.
My previous support ticket numbers are:
 ***deleted personally identifiable information***
Just wondering if anyone else had the same problem (and the fix) and if not, what's the procedure for the refund? I will rather go for a mac then sacrificing $2000+ for a dancing screen.
Kind Regards,
Abbas
2018-05-11T17:59:00+00:00
Hey Everyone,
Creating the best products and experiences for our customers is our top priority.
We have heard your feedback and after careful examination, have determined that a small percentage of Surface Pro 4 devices are exhibiting a screen flicker that cannot be addressed with a firmware or driver update.
To support customers affected by this issue, we will replace eligible Surface Pro 4 devices for up to three years from the date of purchase, free of charge. If you believe your device is experiencing this issue, please visit our Surface Pro 4 screen flicker article for more details.
Bryan [MSFT]
2,779 additional answers
    2018-02-09T08:52:06+00:00
    I have the same problems with my surface Pro4
    2018-02-09T15:45:13+00:00
    Just spent an hour on the phone with MS technical support with this issue...offered the option to pay for a replacement. I would have to send mine in, then wait for them to send a new one back. I'm highly dependent on this machine, and this would cost me ~2 weeks of lost productivity (in addition to what has already occurred).
    These are such expensive machines, marketed as high-end. To have them predictably fail for thousands of users and then be offered the privilege of paying for a replacement is an insult. I have already contacted multiple class-action lawyers to encourage them to take action, and I recommend all other affected users do the same.
    2018-02-09T16:02:57+00:00
    1. Sign our petition https://www.change.org/p/microsoft-microsoft-surface-pro-4-screen-flickering-or-blurry?recruiter=845560982&utm_source=share_petition&utm_medium=copylink&utm_campaign=share_petition
    520 followers
    1. The class action was filed early this week, sign up. https://www.consumerclassactionlawyers.com/microsoft-surface-pro-4-flickering-screen-class-action-lawsuit-investigation.html?t=1&cn=ZmxleGlibGVfcmVjc18y&refsrc=email&iid=796f05f2076843059645d6e99399ea98&uid=734867867334791168&nid=244+281088008
    2.  Copy this message and post it everywhere you can
    2018-02-09T18:00:41+00:00
    Microsoft is using the #MySurface hashtag today to celebrate 5 years of Surface Products, I think we should use the opportunity to highlight the issue with the Surface Pro 4 devices. Add #MySurface to the #Flickergate hashtag. when tweeting.
