Surface Pro 4, Screen Flickering, Shaking
2017-01-19T07:47:47+00:00
Hi All,
Update: Flickergate is now having a forum to bring all affected users at a single platform to plan for resolvement of issue. Please join at
 https://forum.flickergate.com
UPDATE: Check FlickerGate.com for videos of the problem and to submit your own.
I purchased SP4 device a few months ago and it was working fine for a month. Then I noticed that when the CPU is at its max, the screen flickers a bit. Investigating further revealed that it flickers even if it is setting idle. It does not flicker if at least one of the following thing is done:
  1. A video being played in browser
  2. If I keep the touch screen busy by either taping it or keeping a finger on it
  3. If I use the touchpad
  4. If keyboard is used for typing
This resulted in making the device completely unusable while reading articles or ebooks. I am a developer, most of the time I have to read the code and to do that, I have to constantly keep a finger on the touch pad or the screen. I contacted surface support in October and November and was told that the developers are working on the patch. Looking at the updates the developers are pushing since then, I don't think anyone is even aware of the problem there.
My previous support ticket numbers are:
 ***deleted personally identifiable information***
Just wondering if anyone else had the same problem (and the fix) and if not, what's the procedure for the refund? I will rather go for a mac then sacrificing $2000+ for a dancing screen.
Kind Regards,
Abbas
2018-05-11T17:59:00+00:00
Hey Everyone,
Creating the best products and experiences for our customers is our top priority.
We have heard your feedback and after careful examination, have determined that a small percentage of Surface Pro 4 devices are exhibiting a screen flicker that cannot be addressed with a firmware or driver update.
To support customers affected by this issue, we will replace eligible Surface Pro 4 devices for up to three years from the date of purchase, free of charge. If you believe your device is experiencing this issue, please visit our Surface Pro 4 screen flicker article for more details.
Bryan [MSFT]
2,779 additional answers
    2018-02-07T13:38:05+00:00
    Have you tried Jasmine Car's reply on this thread? Also, which Surface device are you using?
    Thank you.
    2018-02-07T16:03:16+00:00
    The jittering/flickering issue can also be connected to a common Touch Screen issue. Does the issue occur when you open the task manager? You might want to apply the hotfix which can be found on this link. The tool may take one to two minutes to complete the calibration.
    If the issue persists, we recommend that you run the Surface Diagnostic Toolkit. It resolves common Surface problems and the diagnosis may take 15 minutes or less, but can take an hour or longer and depending on your internet connection speed and the repairs that the tool needs to do to fix the problems.
    Click here to run the Surface Diagnostic Toolkit.
    We hope this works, and let us know if you have any additional concerns.
    Regards.
  3. Deleted
    2018-02-07T23:26:42+00:00
    Be prepared for MS to call your bluff because that's what they will do. They will not address this because they do not care 1 bit about their customers in the consumer space. This is a company that hates the fact that they have to still deal with even being in the consumer space. So be prepared to either stick to your guns and never buy anything from them again or cave in and buy more Windows devices in the future. MS knows that it is extremely hard for the normal person to completely change platforms and ecosystems so they don't feel the need to do anything to make things right. Notice how not even the Windows guys like Windowscentral and Thurrott are covering this. They extensively covered the previous issues with the SP3 and 4 as well as the Surface Book but they aren't going near this. It's interesting.
