Surface Pro 4, Screen Flickering, Shaking
2017-01-19T07:47:47+00:00
Hi All,
Update: Flickergate is now having a forum to bring all affected users at a single platform to plan for resolvement of issue. Please join at
 https://forum.flickergate.com
UPDATE: Check FlickerGate.com for videos of the problem and to submit your own.
I purchased SP4 device a few months ago and it was working fine for a month. Then I noticed that when the CPU is at its max, the screen flickers a bit. Investigating further revealed that it flickers even if it is setting idle. It does not flicker if at least one of the following thing is done:
  1. A video being played in browser
  2. If I keep the touch screen busy by either taping it or keeping a finger on it
  3. If I use the touchpad
  4. If keyboard is used for typing
This resulted in making the device completely unusable while reading articles or ebooks. I am a developer, most of the time I have to read the code and to do that, I have to constantly keep a finger on the touch pad or the screen. I contacted surface support in October and November and was told that the developers are working on the patch. Looking at the updates the developers are pushing since then, I don't think anyone is even aware of the problem there.
My previous support ticket numbers are:
 ***deleted personally identifiable information***
Just wondering if anyone else had the same problem (and the fix) and if not, what's the procedure for the refund? I will rather go for a mac then sacrificing $2000+ for a dancing screen.
Kind Regards,
Abbas
2018-05-11T17:59:00+00:00
Hey Everyone,
Creating the best products and experiences for our customers is our top priority.
We have heard your feedback and after careful examination, have determined that a small percentage of Surface Pro 4 devices are exhibiting a screen flicker that cannot be addressed with a firmware or driver update.
To support customers affected by this issue, we will replace eligible Surface Pro 4 devices for up to three years from the date of purchase, free of charge. If you believe your device is experiencing this issue, please visit our Surface Pro 4 screen flicker article for more details.
Bryan [MSFT]
2,779 additional answers
    2017-03-21T12:55:16+00:00
    I had the same problem for a while, especially after 2-3 hrs of usage. I have given up on it after Microsoft Tech guys can't solve it. And since my unit is still under warranty, had the replacement process started. hopefully, would not encounter a similar issue with the replacement unit.
    2017-03-22T15:24:03+00:00
    Thank you for trying the mentioned solutions for the issue you're having on your Surface screen.
    Since we have performed the troubleshooting steps and the issue still exists, we recommend that you contact Answer Desk for a warranty replacement. They'll be able to advise you of options.
    2017-03-22T16:36:04+00:00
    I live in Malta and don't have any help desk or support page for this country, can't access chat support, or phone support... I've been having this issue since november last year waiting for a fix, and my warranty ran out last month!!
    2017-03-22T18:21:56+00:00
    Microsoft lists the following support number for Malta:
    Malta N/A 800 62 037 English
    https://support.microsoft.com/en-us/help/13948/global-customer-service-phone-numbers
