Surface Pro 4, Screen Flickering, Shaking
2017-01-19T07:47:47+00:00
Hi All,
Update: Flickergate is now having a forum to bring all affected users at a single platform to plan for resolvement of issue. Please join at
 https://forum.flickergate.com
UPDATE: Check FlickerGate.com for videos of the problem and to submit your own.
I purchased SP4 device a few months ago and it was working fine for a month. Then I noticed that when the CPU is at its max, the screen flickers a bit. Investigating further revealed that it flickers even if it is setting idle. It does not flicker if at least one of the following thing is done:
  1. A video being played in browser
  2. If I keep the touch screen busy by either taping it or keeping a finger on it
  3. If I use the touchpad
  4. If keyboard is used for typing
This resulted in making the device completely unusable while reading articles or ebooks. I am a developer, most of the time I have to read the code and to do that, I have to constantly keep a finger on the touch pad or the screen. I contacted surface support in October and November and was told that the developers are working on the patch. Looking at the updates the developers are pushing since then, I don't think anyone is even aware of the problem there.
My previous support ticket numbers are:
 ***deleted personally identifiable information***
Just wondering if anyone else had the same problem (and the fix) and if not, what's the procedure for the refund? I will rather go for a mac then sacrificing $2000+ for a dancing screen.
Kind Regards,
Abbas
2018-05-11T17:59:00+00:00
Hey Everyone,
Creating the best products and experiences for our customers is our top priority.
We have heard your feedback and after careful examination, have determined that a small percentage of Surface Pro 4 devices are exhibiting a screen flicker that cannot be addressed with a firmware or driver update.
To support customers affected by this issue, we will replace eligible Surface Pro 4 devices for up to three years from the date of purchase, free of charge. If you believe your device is experiencing this issue, please visit our Surface Pro 4 screen flicker article for more details.
Bryan [MSFT]
2,779 additional answers
    2017-08-28T19:16:34+00:00
    Well the biggest software that installed in my sp4 is photoshop cc which is only 3.18 GB. And also the flickers start even when i'm not running it, it is starting to flicker when i'm using my sp4 for a while (2-3 hours) i think it's still a heat issue. But it's still worth a try :)
    2017-08-29T05:37:49+00:00
    Yesterday I ran my i7 SP4 most of the day connected and projecting to only a single external monitor.  Occasionally I would turn on the SP4 display and I did not experience any flickering.  Not sure if this good behaviour is sustainable.  I'll see over the next few days.  This is still not a good solution as I cant use it as a portable device.
    2017-08-29T08:00:19+00:00
    Well,
    I'm using external monitors also.
    The typical abnormal behaviour is:
    1)starts flickering at startup
    1. after say 15 minutes.." Ghosting"
    2. after say 90 minitutes neither ghosting nor flickering...screen's normal but hotter?
    3. after 5/6 hours overheating and emergency shut down...
    2017-08-29T19:14:45+00:00
    Does anybody know what all the workarounds are? The seconds and task manager no longer work for me after almost immedietly turning on the machine.
    I will add that this originally started happening after employing iMacro scripts. I stopped using the scripts until recently and they appear to have pushed the surface into this unusable state. I'm going to go throw up now.
