Surface Pro 4, Screen Flickering, Shaking
2017-01-19T07:47:47+00:00
Hi All,
Update: Flickergate is now having a forum to bring all affected users at a single platform to plan for resolvement of issue. Please join at
 https://forum.flickergate.com
UPDATE: Check FlickerGate.com for videos of the problem and to submit your own.
I purchased SP4 device a few months ago and it was working fine for a month. Then I noticed that when the CPU is at its max, the screen flickers a bit. Investigating further revealed that it flickers even if it is setting idle. It does not flicker if at least one of the following thing is done:
  1. A video being played in browser
  2. If I keep the touch screen busy by either taping it or keeping a finger on it
  3. If I use the touchpad
  4. If keyboard is used for typing
This resulted in making the device completely unusable while reading articles or ebooks. I am a developer, most of the time I have to read the code and to do that, I have to constantly keep a finger on the touch pad or the screen. I contacted surface support in October and November and was told that the developers are working on the patch. Looking at the updates the developers are pushing since then, I don't think anyone is even aware of the problem there.
My previous support ticket numbers are:
 ***deleted personally identifiable information***
Just wondering if anyone else had the same problem (and the fix) and if not, what's the procedure for the refund? I will rather go for a mac then sacrificing $2000+ for a dancing screen.
Kind Regards,
Abbas
2018-05-11T17:59:00+00:00
Hey Everyone,
Creating the best products and experiences for our customers is our top priority.
We have heard your feedback and after careful examination, have determined that a small percentage of Surface Pro 4 devices are exhibiting a screen flicker that cannot be addressed with a firmware or driver update.
To support customers affected by this issue, we will replace eligible Surface Pro 4 devices for up to three years from the date of purchase, free of charge. If you believe your device is experiencing this issue, please visit our Surface Pro 4 screen flicker article for more details.
Bryan [MSFT]
2,779 additional answers
    2019-02-20T13:47:02+00:00
    Same here.... i'm going back to Dell products , I never had a thecnical issue not solved by them
    2019-02-20T10:40:14+00:00
    Hi I've experienced the same problem, which only seems to start once the device is conveniently out of warranty.
    The best solution that I've found is to abandon Microsoft Surface Pro devices completely, as clearly Microsoft, whilst acknowledging creating this problem, pretend that only a "small percentage" of devices experience this probem.
    Probably like me, most customers, once out of warranty, choose simply to dump their Surface Pro product and seek an alternative.
    Microsoft need to address the core problem of the device overheating.
    2019-02-18T16:31:54+00:00
    great -- my surface pro 4 started jittering/shaking!
    2019-02-18T07:49:47+00:00
    Hi Brian
    I've attempted to sort my issue with the virtual agent without success. I have a Surface Pro 4 with a flickering screen. I purchased it in September 2016. Can you advise a possible solution for this problem?
    Thanks.
