Surface Pro 4, Screen Flickering, Shaking
2017-01-19T07:47:47+00:00
Hi All,
Update: Flickergate is now having a forum to bring all affected users at a single platform to plan for resolvement of issue. Please join at
 https://forum.flickergate.com
UPDATE: Check FlickerGate.com for videos of the problem and to submit your own.
I purchased SP4 device a few months ago and it was working fine for a month. Then I noticed that when the CPU is at its max, the screen flickers a bit. Investigating further revealed that it flickers even if it is setting idle. It does not flicker if at least one of the following thing is done:
  1. A video being played in browser
  2. If I keep the touch screen busy by either taping it or keeping a finger on it
  3. If I use the touchpad
  4. If keyboard is used for typing
This resulted in making the device completely unusable while reading articles or ebooks. I am a developer, most of the time I have to read the code and to do that, I have to constantly keep a finger on the touch pad or the screen. I contacted surface support in October and November and was told that the developers are working on the patch. Looking at the updates the developers are pushing since then, I don't think anyone is even aware of the problem there.
My previous support ticket numbers are:
 ***deleted personally identifiable information***
Just wondering if anyone else had the same problem (and the fix) and if not, what's the procedure for the refund? I will rather go for a mac then sacrificing $2000+ for a dancing screen.
Kind Regards,
Abbas
2018-05-11T17:59:00+00:00
Hey Everyone,
Creating the best products and experiences for our customers is our top priority.
We have heard your feedback and after careful examination, have determined that a small percentage of Surface Pro 4 devices are exhibiting a screen flicker that cannot be addressed with a firmware or driver update.
To support customers affected by this issue, we will replace eligible Surface Pro 4 devices for up to three years from the date of purchase, free of charge. If you believe your device is experiencing this issue, please visit our Surface Pro 4 screen flicker article for more details.
Bryan [MSFT]
2,779 additional answers
    2019-05-28T01:01:37+00:00
    Hi
    Im having same issues for 3 years now! I paid 1700 GBP for device that didn't worked longer than few months... in the best scenario. First purchase - 28 December 2016
    Overheating, switching off and screen flickering makes impossible to use this device - so I was kindly offered and exchange, by now (May 2019) it's 8 TIMES!
    16 May 2019
    20 January 2019
    20 September 2018
    27 August 2018
    8 August 2018
    14 March 2018
    30 July 2017
    4 January 2017
    The latest replacement is 3 days old - and here we go again - feels like Im going blind!
    For a little while is human eye ties to adapt to it! So I think its very demanding not only to my work but to my health as well! Good Im not epileptic LOL
    THIS replacement process is getting ridiculous! All those reinstallations are time consuming and have negative affect on my work and health!
    I do own Surface Pro 3 and its still works just fine - never had issues with it.
    For all this time I was refused refund, different model or at least BRAND NEW product - I keep getting refurbished devices - which are having same issues or even worst
    Im mean ****? Why did I spend 1700 GBP for device that even after 8 replacement didn't last 2 years warranty period?!?!
    2019-05-27T18:48:06+00:00
    I had my issue resolved, I just recommend everyone to call Microsoft support ,
    Personally me didn't have problem to talk to the adviser, so , I would recommend to call the # from the list, given in this site
    https://support.microsoft.com/en-us/help/4230448/surface-pro-4-screen-flicker
  3. Barb Bowman 80,810 Reputation points MVP Volunteer Moderator
    2019-05-27T08:59:25+00:00
    They are replacing with refurbs if 3 years or less from date of original
    purchase at no charge.
    2019-05-27T06:32:48+00:00
    The product will not repaired with the flickering. Additionally, they will not replacement unless you are under warranty. The best solution is to either purchase a replacement from your nearest Microsoft store or buy a new laptop entirely.
    Hope this helps you and others.
    Max M.
