Same problem as everyone else, January 7, 2025, not charging consistently, no notice battery is low until the trackpad stops working. Extremely disappointing for a premium priced product, especially when the Surface Pro is such a wonderful device. Also, it should have a dedicated charging port for when it's not attached to the tablet. The battery is not going to last nearly as long as the tablet battery, since I mostly plug in the tablet and detach the keyboard. The typing & trackpad experience is good, but I regret the purchase (for the price to value ratio).
Surface Pro Flex Keyboard Charging issues
I've seen multiple other posts on this, but I'm confused as to Microsoft doesn't issue an update.
I have the new Surface Pro 11, with the Flex Keyboard. The keyboard does NOT charge when I attach the keyboard to the device when the device is not plugged into a charger.
The keyboard does NOT charge when the deviced is plugged into a charger, and the keyboard is closed (sleep mode).
It only charges (and even this is sporatic) when the keyboard is attached and the device is plugged into a charger. Sometimes it will charge, other times it will not. I have yet to find a pattern, but that is the only time it will charge (and that is still only about 1/2 of the time).
I have tried all the basic trouble shooting (cleaing the connectors, ESC key for 5 seconds to turn off keyboard, updated all firmware). This is obviously an issue that Microsoft is ignoring.
Any ideas would be welcome, but my thought is that it just doesn't charge like it's supposed to, and nothing is really going to change that...
Surface | Accessories | Surface Type Cover
2025-01-07T20:28:52+00:00 -
2025-01-08T05:33:31+00:00 Hello, everyone. Interestingly, has anyone seen the official response of the company on this issue? Or do they not care about us and pretend that there is no problem?
2025-01-09T06:43:51+00:00 i find not even turning on the backlight even the dimmest the battery lasts much longer. on the surface twitter i asked them for the charger they are quiet. singapore
2025-01-21T01:28:07+00:00 Ditto to all you and the others said. The battery issue is a pain. In my experience, the keyboard ONLY charges when: (a) the Surface Pro is on; and (b) the Surface Pro is connected to the Surface Charger. When I turn off the Surface Pro, I cannot get the keyboard to charge even if the Surface Pro is connected to and stored with the charger on. The SP stays charged, but the keyboard power just trickles down.
As to the issue of it becoming unresponsive, one thing I have found is that it goes to sleep after a short period and is unresponsive. To "wake it up," I have had success by hitting the "windows" key. After I tap that key, the rest of the keyboard wakes up.
Another problem I had was with the trackpad. I could not get it to scroll on pages using two fingers. MS Support did help me resolve that. Here is what they did (after doing the usual to make sure I had all the updates): (1) Close all important stuff and save your open documents, etc.; (2) Open Task Manager (using ctrl-alt-del or whatever method you wish); (3) Click on the "Processes" tab (tabs on left) if it is not already selected (it is normally the default tab selected); (c) Go to the bottom of the list of processes until you see the folder for "Windows Explorer"; (d) click on "Windows Explorer"; (e) on the upper bar, click on "restart task"; (f) hold down the power button until the screen goes completely black (that hard re-starts everything); (g) wait 30 seconds; (h) turn the computer back on. At least for me, that re-set of whatever got re-set made it where scrolling with the trackpad worked again.
Ugh on the battery issue.
2025-01-21T01:52:25+00:00 I guess it's probably time to consult an attorney. This keyboard does not work like it should and was designed. Would any of you be interested in joined a class action lawsuit on this? It's absurd that Microsoft hasn't responded with a legitimate fix.
