Can't adjust screen brightness on Surface Pro 4. Not with the keyboard or with action center.
2017-05-08T08:50:00+00:00
I am having a problem with adjusting the screen brightness on my Surface Pro 4.
(It happened a few days after the new Windows 10 Creators update)
I can't change with neither the keyboard using "FN+Del" or "FN+Backspace", nor with using the Action center or Battery icon.
What I have done and observed:
  • The adjust screen brightness button is NOT greyed out (see picture)
  • When I try to change screen brightness with the keyboard I get the blue bar (as with volume controls) showing I am changing the brightness, but visually it has not changed. (see picture)
  • I've tried to update my Display Adapter using Device Manager.
  • I've tried to change my Display Adapter by "Let me pick from a list of device drivers on my computer" from Intel HD Graphics 520 to Microsoft Basic Display Adapter.
  • I've tried to turn off "Adjust my screen brightness automatically".
  • I've tried to update my screen monitor drivers in Device Manager.
  • I tried to change my Screen Monitor with "Let me pick from a list of device drivers on my computer" from Surface Display to Generic PnP-Monitor .
    • This worked to change my screen brightness the moment I changed the driver. However, it only changes to which setting I had changed to with action center or the keyboard. The keyboard and action center still doesn't work after changing the driver. Meaning I have to go to Device Manager and change my Screen monitor driver every time I want to change the brightness of my screen, as it only changes the moment I change driver.
Please help me!
2017-06-13T14:41:24+00:00
Hi there folks!
I had the exact same issue occur with my own Surface Pro 4 this week.
What triggered the issue was that I closed my Surface Pro without the Keyboard attatched, then it later went to Hybernate mode by it self (as it's supposed to)
Then I attached the Keyboard meanwhile it was in Hybernate and after woke it up.
Then the problem was there.. It left me thinking that I would think through what I had done and try to reverse what I already did.
The fix for me was simply to detatch the keyboard, then rebooting the computer without the keyboard, then suddenly it was fixed!
I was able to attatch the keyboard yet again and it still worked like a charm!
Once again in a more structrured manner:
  1. Make sure the surface is On and at the desktop or such alike.
  2. Detatch the keyboard.
  3. Use the touch screen in order to carry out a reboot.
  4. when at the desktop yet again, I personally swiped the screen from the right to bring out the notification center. To then use the touch screen to change the brightness.
  5. I attatched the keyboard and made sure that the problem didn't still persist. (which I was successful in)
PS: Might be that there was some other thing that triggered your problem, however this was the story of my problem and how I fixed it.
Hope this helps any of you guys.
Cheers,
Adrian.
2017-05-10T04:38:50+00:00
Going back to the steps given above, Have you already come upon on the gamma adjustment screen? In this screen, you can adjust the brightness of your monitor by moving the slider up or down.
Let us know if this works on your computer.
41 additional answers
    2017-07-05T17:57:22+00:00
    I agree. I've tried almost everything in this question thread, as well as others. Starting to wonder how long until the bug fix, hoping it's soon like you said.
    Update : Continued trouble shooting and restarting with the keyboard connected as well as disconnected, with brightness all the way up and all the way down. Final combination that fixed not being able to dim or brighten the screen: Keyboard attached, brightness all the way up, restart. (This was my 4th restart)
    Best of luck to anyone still having this issue. Seems like messing with settings, and turning things on and off seemed to get my surface pro4 back on track.
    2017-07-13T20:49:02+00:00
    Same here, it's terrible, im really pretty upset, the luminosity is at it max and there s nothing i can do. wtf Microsoft....
    2017-07-30T17:34:35+00:00
    Never Ever Shall I get a Microsoft piece of hardware again in my life. This Surface Pro has been nothing but trouble, how on earth are they able to make such a mess. Really, I am stunned.
    Now this again. I am looking into the sun right now, this brightness is just too much and I cant for the life of me turn it down, whatever I try.
    I am sereously thinking about smashing it against the wall right now and I promise myself to never again buy a MS piece of hardware.
