Can't adjust screen brightness on Surface Pro 4. Not with the keyboard or with action center.
2017-05-08T08:50:00+00:00
I am having a problem with adjusting the screen brightness on my Surface Pro 4.
(It happened a few days after the new Windows 10 Creators update)
I can't change with neither the keyboard using "FN+Del" or "FN+Backspace", nor with using the Action center or Battery icon.
What I have done and observed:
  • The adjust screen brightness button is NOT greyed out (see picture)
  • When I try to change screen brightness with the keyboard I get the blue bar (as with volume controls) showing I am changing the brightness, but visually it has not changed. (see picture)
  • I've tried to update my Display Adapter using Device Manager.
  • I've tried to change my Display Adapter by "Let me pick from a list of device drivers on my computer" from Intel HD Graphics 520 to Microsoft Basic Display Adapter.
  • I've tried to turn off "Adjust my screen brightness automatically".
  • I've tried to update my screen monitor drivers in Device Manager.
  • I tried to change my Screen Monitor with "Let me pick from a list of device drivers on my computer" from Surface Display to Generic PnP-Monitor .
    • This worked to change my screen brightness the moment I changed the driver. However, it only changes to which setting I had changed to with action center or the keyboard. The keyboard and action center still doesn't work after changing the driver. Meaning I have to go to Device Manager and change my Screen monitor driver every time I want to change the brightness of my screen, as it only changes the moment I change driver.
Please help me!
2017-06-13T14:41:24+00:00
Hi there folks!
I had the exact same issue occur with my own Surface Pro 4 this week.
What triggered the issue was that I closed my Surface Pro without the Keyboard attatched, then it later went to Hybernate mode by it self (as it's supposed to)
Then I attached the Keyboard meanwhile it was in Hybernate and after woke it up.
Then the problem was there.. It left me thinking that I would think through what I had done and try to reverse what I already did.
The fix for me was simply to detatch the keyboard, then rebooting the computer without the keyboard, then suddenly it was fixed!
I was able to attatch the keyboard yet again and it still worked like a charm!
Once again in a more structrured manner:
  1. Make sure the surface is On and at the desktop or such alike.
  2. Detatch the keyboard.
  3. Use the touch screen in order to carry out a reboot.
  4. when at the desktop yet again, I personally swiped the screen from the right to bring out the notification center. To then use the touch screen to change the brightness.
  5. I attatched the keyboard and made sure that the problem didn't still persist. (which I was successful in)
PS: Might be that there was some other thing that triggered your problem, however this was the story of my problem and how I fixed it.
Hope this helps any of you guys.
Cheers,
Adrian.
2017-05-10T04:38:50+00:00
Going back to the steps given above, Have you already come upon on the gamma adjustment screen? In this screen, you can adjust the brightness of your monitor by moving the slider up or down.
Let us know if this works on your computer.
41 additional answers
    2017-12-25T23:28:51+00:00
    Thank you for your advice, Adrian. You probably can't help me with this since you're not the Microsoft company, but I'll ask anyway. I just got my Surface Pro 4 and I haven't bought a keyboard for it yet. It's had this problem since I first turned it on, and since I don't have a keyboard, I can't exactly fix it this way. I completely understand if nobody can help me. I will probably just deal with it until I get a keyboard, but I will certainly try this when I get one. Thanks again.
    -Katie
    2018-01-24T20:23:18+00:00
    I had the same problem in Fall Creators Update on Pro 4
    I have Teamwiever display driver installed.
    Fix issue by unistalling Monitor Driver in Teamwiever options.
    If not works you can try to delete all 3rd party programs which can work (or cooperate) with display such as USB Video/DLNA/Wireless Display drivers, capture software, other drivers.
    It may work
    2018-04-13T11:44:06+00:00
    I've read through the thread as I have had the same problem since the Creator's Update and haven't found a suitable fix until now.
    Firstly a list of the problems I had:
    • Brightness was permanently set to nova (100%) and could not be altered, even with keyboard shortcuts or the Microsoft Moderator's suggestions
    • Screen would occasionally freeze and require a soft reset to un-freeze the screen
    • Brightness bar was missing
    • Brightness shortcut in the Notifications Centre was also missing
    • Night Light was greyed out and could not be selected
    • Intel Graphics device could not be found in Device Manager
    I tried everything that was suggested in this thread, even the keyboard reset method for those who had a slight glitch due to their keyboard attachment not being properly detached.
    It was suggested to me that because I could not find my Intel Drivers in the Device Manager programme that I go directly to the Intel website and reinstall the most up-to-date version of the driver that should be already installed.
    For my Surface Pro the "About" section states that my processor is an Intel(R) Core(TM) M3-6Y30 @ 0.90GHz 1.51GHz. So I went to Intel's Download Centre and selected "processors", then defined the search by "Intel Core Processors" and then defined further with "6th Gen Intel Core M processors", and found the most recent driver download for Windows 10 (64-bit). I downloaded this and followed the instructions on-screen.
    Since the restart I have had a brightness shortcut on the Notification Centre, I can use the keyboard shortcuts to adjust brightness, and the wondrous brightness slider bar is back! Once again I can feel my eyes that are no longer being burned out by the supernova that was my Surface Pro screen. I hope this helps a few of you with the problem, but I think there are multiple factors making each fix suggested by people very specific and will not always work with other's devices.
    -DG
