How do I disable Pinch Zoom on Touchpad Surface Pro 3
2014-11-28T16:26:57+00:00
I have a Surface Pro 3 with the Surface Pro Type Cover.  I also have big hands and find too often I am inadvertently hitting the touchpad and zooming out (mostly) and in.  How can I disable the pinch zoom feature on the touchpad?  I have already disabled the tap feature to avoid inadvertently moving the cursor and disabled Caps Lock as these were problems as well.
PS: I love the Pro 3 (after getting used to Windows 8.1).  My MacPro using girlfriend is very jealous.
Surface | Surface Headphones | Touch and gestures
2014-11-30T00:05:11+00:00
Hello BobC1958,
I understand that your hands are accidentally making the gesture to zoom in on your Surface Pro 3. I'll do what I can to help you with this.
I've gone through the settings and cannot find a way to turn this off. You could disable the touchpad altogether in pc settings and use a mouse. It may not be the solution you are looking for, but it would work as a workaround.
Let us know if that works or if you have any other questions.
Best Wishes,
Zack_T
14 additional answers
    2016-12-12T17:26:06+00:00
    No Sensor settings... just tried. Does not work.
    This works in Win 10 but NOT in win 8.1   Apparently, nothing will turn off this annoying "feature"in win 8.1.  If I have to switch to win10 I  am ready to dump my 2-year old SP3 for a new DELL xps13.
    Also, I am having the battery problem where my caoacity ia down to 10 or 15 min pf battery life.  I am now VERY disapointed and very unhappy with the SP3.
    2016-12-15T22:06:07+00:00
    You may find this linkhelpful regarding on how to disable Pinch Zoom on Touch pad Surface Pro 3. Also, to answer your query, you may create a new thread for your battery issue.
    Regards.
