How do I disable Pinch Zoom on Touchpad Surface Pro 3
2014-11-28T16:26:57+00:00
I have a Surface Pro 3 with the Surface Pro Type Cover.  I also have big hands and find too often I am inadvertently hitting the touchpad and zooming out (mostly) and in.  How can I disable the pinch zoom feature on the touchpad?  I have already disabled the tap feature to avoid inadvertently moving the cursor and disabled Caps Lock as these were problems as well.
PS: I love the Pro 3 (after getting used to Windows 8.1).  My MacPro using girlfriend is very jealous.
Surface | Surface Headphones | Touch and gestures
2014-11-30T00:05:11+00:00
Hello BobC1958,
I understand that your hands are accidentally making the gesture to zoom in on your Surface Pro 3. I'll do what I can to help you with this.
I've gone through the settings and cannot find a way to turn this off. You could disable the touchpad altogether in pc settings and use a mouse. It may not be the solution you are looking for, but it would work as a workaround.
Let us know if that works or if you have any other questions.
Best Wishes,
Zack_T
14 additional answers
    2016-07-08T20:07:22+00:00
    Really?  Is there really no way to disable this extremely infuriating function?  I spend more time online correcting the zoom than I do getting anything done.
    I do not accept the requirement of upgrading to 10 to address this.  Microsoft's only answer to every technical problem is to "upgrade" - where they fix one problem and dish out a half-dozen more.
    Please, PLEASE - provide a means by which to eliminate the pinch-zoom function in Windows 8 / 8.1
    2016-07-18T01:44:16+00:00
    Turn Off Pinch Zoom On Surface Pro 3 With Windows 10
    Go To Control Panel
    Hardware and Sound
      View Devices and Printers
    Right Click On Tablet 1
      Left Click On Sensor Settings
         Click <-- Button Near Settings At Top Left Corner
           Left Click On Devices
              Left Click On Touchpad and Mouse
                  Go Down To "Use a two finger touch to zoom" - Turn it off
    2016-12-12T16:30:25+00:00
    No Sensor settings... just tried. Does not work.
    2016-12-12T17:24:36+00:00
    This works in Win 10 but NOT in win 8.1   Apparently, nothing will turn off this annoying "feature"in win 8.1.  If I have to switch to win10 I  am ready to dump my 2-year old SP3 for a new DELL xps13.
