what I can suggest is to reimage your Surface device using a USB recovery drive (if you haven't reset the device yet). Reimaging your Surface using a USB recovery drive is a complete form of reset and if the issue persists after the reset,
once these start flickering, simply booting to the UEFI will most likely show
the same flickering. waste of time to reimage.
Barb,
Thanks for your hopeful response.
I'm not tech-savvy, so I'll attempt to re-image my Surface Pro 4 using a USB recovery with apprehension and caution. I am very happy with my Surface Pro and was very disappointed that I might have to replace it or face high cost repairs.
I am hopeful this will work.
OOOOPS!
I just read: "https://www.most-useful.com/screen-flickering-on-surface-pro-4-solved/".
It's not solved!
My Surface Pro is 3 years six months old. I expected longer life. What can we do to to win Microsoft's support to fix their problem?
Cheers, Sam
