Bluetooth Surface Laptop 3 disconnects and reconnects for no reason
2019-12-05T17:17:32+00:00
Every day, my bluetooth on my Surface Laptop disconnects and reconnects for no reason.  I am using a microsoft designer mouse and keyboard.  This happens multiple times each day.
I have tried all the standard items,
readding the bluetooth device
restarting the computer
ensure the laptop power settings are correct
making sure all updates have been installed
etc.
Anyone having these issues?  Any fix ?
Surface | Surface Laptop | Install and update
    2020-09-29T06:59:55+00:00
    Just wanted to share this: Intel updated their Bluetooth drivers for the Surface Laptop 3 and so far, it's working without any issues.
    Use the Intel® Driver & Support Assistant to check for new drivers and download the new bluetooth ones ( 21.120.0.4 ):
    https://www.intel.com/content/www/us/en/support/intel-driver-support-assistant.html
    Hope it helps!
    2020-10-20T18:14:08+00:00
    I used to have it fixed after trying this. But then I had to do a factory reset on my laptop.
    Now I don't have the option anymore to turn of Power Management. The whole tab just vanished.
    Any other ways around this problem?
    2020-10-21T09:59:32+00:00
    I am having the same issue after  the update.
    Does anybody knows another way of fixing it?
