The clipboard/screen, when detached has a Surface Connect port - plug the cable
that goes from the dock into that.
> How do I "run the dock updater from the clipboard"?
I have Surface book 13.5, and Surface Dock. USB ports on the dock are not working.
Running Surface Dock updater says I need to power cycle the dock, although I already did it several times.
Event viewer reports error code 12105, with message: "Failed to update USB hub firmware."
Hi Barb,
Here are my logs:
https://1drv.ms/u/s!AptlAPQnDv9Ug7MRz8S4iya\_Zk2biQ
Here is my winver
I've cleared all as suggested. Also did this through clipboard with dock attached and same error.
Thank you.
Joel
I don't see the version and build from Winver. Please repost this.
Hi Barb,
Here it is.
Build 1079 (OS Build 16299.309)
Thanks.
I think your best option at this point is to exchange your dock, sorry.
