Seriously Windows, get your act together here. I really want my dock to work!!!!!!
Surface Dock USB ports not working - Dock Updater repeatedly fails
I have Surface book 13.5, and Surface Dock. USB ports on the dock are not working.
Running Surface Dock updater says I need to power cycle the dock, although I already did it several times.
Event viewer reports error code 12105, with message: "Failed to update USB hub firmware."
2018-03-15T20:50:21+00:00 -
2018-03-19T15:26:53+00:00 I have a user that has been using a Surface Book with dock for about a month. Thursday of last week, the user reported that the keyboard/mouse (wireless logitech) stopped working. When I unplugged and plugged in the USB receiver, it would start to work. However it only worked for about a day, then it would stop working again. So far the only way to get the keyboard/mouse to work is to plug it into the Surface Book directly. I took the Surface Book home over the weekend and could not find anything wrong. I then came in this morning and ran the MS Dock Update Utility which seems to have issues (as a lot of people are reporting), when I logged out, the user reported that the keyboard/mouse stopped working on the login screen. Again, I plugged it directly into the Surface Book and it is currently working but for how long. I am temped to replace the dock since I have a spare, but after reading some of these post I am reluctant. I wish MS would read these posts and actually do something other than let us post over and over and not get any support other than to take the whole thing to a MS store, or if you do not have one, to call in. MS can you please fix this issue?
Barb Bowman 80,810 Reputation points MVP Volunteer Moderator2018-03-19T17:42:49+00:00 For those of you still having issues, can you post the exact error message and error number?
We would like to see Microsoft Surface Dock Updater tool event log so if you could post that to OneDrive and share a link here.
Uninstall of the .MSI and delete files in C:\program files\microsoft\surface\Dock Updater should clear everything out if you want to try again to update.
2018-03-19T17:45:09+00:00 For those of you still having issues, can you post the exact error message and error number?
Barb,
I am not getting any errors when updating the dock, for me it just simply decides not to recognize the wireless keyboard/mouse.
2018-03-20T12:40:56+00:00 I uninstalled my Dock Updater, removed the MSI, and downloaded a new MSI from https://www.microsoft.com/download/details.aspx?id=46703.
I don't have any folder *C:\program files\microsoft*.
After reinstalling the Dock Updater, and retrying the update, it still failed. The Event Viewer shows seven events, with three event type IDs, and one of them marked as an error. I've uploaded the events here: https://1drv.ms/u/s!AlSneZRP6kikli2g3UosSIyX4044
The update tentative after reinstalling the updater is the set of events after 12:31 (GMT).
Please let me know if you need additional info.
