Surface Dock USB ports not working - Dock Updater repeatedly fails
2018-01-02T11:42:03+00:00
I have Surface book 13.5, and Surface Dock. USB ports on the dock are not working.
Running Surface Dock updater says I need to power cycle the dock, although I already did it several times.
Event viewer reports error code 12105, with message: "Failed to update USB hub firmware."
    2019-07-02T18:20:18+00:00
    I have purchased 12 Microsoft Surface Docks for our offices and 5 of the docking stations have had this exact problem. I try to run the Surface Dock Updater and nothing works. I always have to call Microsoft Support and they send out a new dock... This seems to be a known problem, is there no fix to this yet? Are all Surface Docks Defective and the USB Ports consistently stop working?
    2019-07-02T18:24:08+00:00
    You have got to be kidding me... This just worked for me as well. I have replaced 5 Surface Docks in the past year because my USB ports stopped working. This is such a strange fix. THANK YOU!!
