Surface Pro 7 Front Camera Not Working
2019-10-29T19:25:09+00:00
I'm not sure when it started, since I hadn't used the front camera on the device at all, but today I noticed in the Device manager that the "Surface Camera Front" has an error:
This device cannot start. (Code 10) STATUS_DEVICE_POWER_FAILURE.
Sure enough, upon opening the camera app, it acts as though I only have the back camera installed.  I am predictably unable to bring up the front camera.
Is there possibly a driver issue, or is this a hardware flaw?
Thanks!
**Edit**: Problem persists through reboots, disable/reenable, troubleshooter, etc.  Notably, I realized the front camera worked for at least the first hour that I had the device, since it shows you the camera feed when setting up Windows Hello.
Surface | Surface Pro | Sound and camera
    2020-10-21T20:18:50+00:00
    Hi, I also am going through the process of a replacement for the same issue! It's very disappointing.
    How is the replacement computer? Is it new and problem free!?
    2020-10-22T01:06:37+00:00
    Hello, it is not to replace a new computer, but to return to the factory for repair.  After free maintenance, it is currently running well.
    2020-10-27T12:46:54+00:00
    It worked. But in the automatic upgrades, why do the drivers (camera, audio) not get repaired and updated automatically?
    2020-11-13T01:50:15+00:00
    I have the same problem and I also will not ever purchase a Microsoft computer again!
    2020-11-22T16:26:45+00:00
    The same thing happened to me after a recent Windows update.  Here is the solution that finally fixed it for me:
    • Open "Device Manager"
    • Under “System devices”, there are 3 entries for “Intel Control Logic”.  Right-click the first (topmost) “Intel Control Logic” in the list, then select “Update driver”
    • Click “Browse my computer for driver software”
    • Click “Let me pick from a list of available drivers on my computer”
    • Select the 12/16/2019 version of the driver (42.18362.3.196)
    • Click “Next”
    • Click “Close”
    • Click “Yes” to restart the computer
    Thank you for your information and support. I have returned the machine to the factory for overhaul, and the problem has been resolved.
    I am greatly excited and most appreciative - this worked for me!
    In actual fact, this is the only one of the scores of suggestions I got which worked for me.
    In my case though, I did not have the "12/16/2019 version of the driver (42.18362.3.196)".
    My Surface Pro 7 had two more recent versions (2020) of the driver; I selected the older one.
    It worked like magic and in seconds!
    I had spent hours troubleshooting from the previous night and was almost giving up. I'm grateful that I did not. Thanks so much.
