2012-11-01T20:24:52+00:00
Surface | Other
2013-01-11T22:49:32+00:00
Hi NoBoundaries.
To select enhancements:
  2. Tap or click Search
  3. Type "volume"
  5. Tap or click Speaker icon
  6. Select Enhancements tab
2012-11-21T19:43:44+00:00
Hi Danieleyassu,
I hope this helps!
David
2012-11-01T22:56:05+00:00
2012-11-09T21:43:21+00:00
2014-03-30T23:40:07+00:00
Hi lix2k3
  1. Go to your desktop
  2. Click on control panel
  3. Go to Hardware and Sound
  4. Click on Sound
  6. Go to enhancements
Regards
Kevin N.
2013-08-14T18:31:26+00:00
2013-03-09T00:24:09+00:00
Hello MiguelVemba,
Best regards.
2013-01-08T22:01:52+00:00
Bricr
2013-01-02T15:06:17+00:00
Hi Boonie46.
Thanks!
2012-12-13T02:09:55+00:00
Hello mvb0351,
Rebecca_AA1
2012-11-29T00:30:25+00:00
Hello Troy,
267 additional answers
    2012-12-26T23:36:17+00:00
    I respect your opinions but personally I find them unfounded.
    Firstly whilst the iPad is only MONO there is no denying the audio volume and output clarity are superior.  Additionally the lack of any audio control on the Surface is really irritating at best.  This is a standard feature that phones and devices from many years ago featured so is essential in my opinion.
    Secondly whilst machine dimensions play a large role in audio quality clearly this is one area that can and should have been improved especially when competing devices of varying dimensions (some slimmer than the Surface) manage it.
    If Microsoft are serious about the tablet market then they need to pay attention to these limitations with a view to resolving these.
