2012-11-01T20:24:52+00:00
Surface | Other
2013-01-11T22:49:32+00:00
Hi NoBoundaries.
To select enhancements:
  2. Tap or click Search
  3. Type "volume"
  5. Tap or click Speaker icon
  6. Select Enhancements tab
2012-11-21T19:43:44+00:00
Hi Danieleyassu,
I hope this helps!
David
2012-11-01T22:56:05+00:00
2012-11-09T21:43:21+00:00
2014-03-30T23:40:07+00:00
Hi lix2k3
  1. Go to your desktop
  2. Click on control panel
  3. Go to Hardware and Sound
  4. Click on Sound
  6. Go to enhancements
Regards
Kevin N.
2013-08-14T18:31:26+00:00
2013-03-09T00:24:09+00:00
Hello MiguelVemba,
Best regards.
2013-01-08T22:01:52+00:00
Bricr
2013-01-02T15:06:17+00:00
Hi Boonie46.
Thanks!
2012-12-13T02:09:55+00:00
Hello mvb0351,
Rebecca_AA1
2012-11-29T00:30:25+00:00
Hello Troy,
267 additional answers
    2012-12-21T16:32:35+00:00
    Does anybody else agree with me that the audio quality on the Surface RT is poor at best.  There doesn't appear to be any control for treble or base of any kind anywhere and the audio volume at it's highest level is not very loud.  I don't know if this is a hardware limitation or software - I hope it's a software thing and that Microsoft is going to improve it.  I'm the only person I know that has a Surface and each time I show people they're impressed ... but they've frequently asked me to turn up the volume ... and at full volume there's still not much coming out of the device.  Now the Apple iPad ... there's a good audio experience.
    And strangely, occasionally without being able to identify a pattern on how this happens, but sometimes when I'm holding he surface with the keyboard while attached to the machine, the audio gets muted, and no I don't have fat fingers accidentally hitting the mute key.  very strange.
    Two points you should consider here: 1) the iPad (I have the new 4th generation) is only MONO, not stereo, so I don't see how that qualifies as such a great audio experience; and 2) the surface is significantly less bulkier than the iPad (not to mention far, far more comfortable to hold in all positions because of the light weight and more sensible grade of the bezel) and has longer battery life. All this awesomeness has to mean a tradeoff somewhere. Audio still great with headphones, too. I am ditching the iPad all the way. But waiting for surface running Win8 PRO.
