2012-11-01T20:24:52+00:00
Surface | Other
2013-01-11T22:49:32+00:00
Hi NoBoundaries.
To select enhancements:
  2. Tap or click Search
  3. Type "volume"
  5. Tap or click Speaker icon
  6. Select Enhancements tab
2012-11-21T19:43:44+00:00
Hi Danieleyassu,
I hope this helps!
David
2012-11-01T22:56:05+00:00
2012-11-09T21:43:21+00:00
2014-03-30T23:40:07+00:00
Hi lix2k3
  1. Go to your desktop
  2. Click on control panel
  3. Go to Hardware and Sound
  4. Click on Sound
  6. Go to enhancements
Regards
Kevin N.
2013-08-14T18:31:26+00:00
2013-03-09T00:24:09+00:00
Hello MiguelVemba,
Best regards.
2013-01-08T22:01:52+00:00
Bricr
2013-01-02T15:06:17+00:00
Hi Boonie46.
Thanks!
2012-12-13T02:09:55+00:00
Hello mvb0351,
Rebecca_AA1
2012-11-29T00:30:25+00:00
Hello Troy,
267 additional answers
    2012-12-21T12:57:46+00:00
    This is not a good answer. I like to watch videos while cooking and doing dishes and you can hardly hear the sound. I have to use my iPad (that I now have to borrow from my gf) which is at least 2 to 3 times louder. The other day had to use my gf's iPhone to play a YouTube video because we could barely hear it on the Surface. This was late at night, no background noise at all. Her iPhone was probably at 30% and sounded like the Surface at a 100%.
    I have tried every fix suggested on this site, even tried facing the screen backwards because I thought maybe due to the angled bezel having the speakers face me would make it better but nope sounds the same. So the form factor argument is a weak one. I have stopped listening to music in the shower because it is just a waste of time - I now use my HTC Radar to do that.
    Terry
