2012-11-01T20:24:52+00:00
Surface | Other
2013-01-11T22:49:32+00:00
Hi NoBoundaries.
To select enhancements:
  2. Tap or click Search
  3. Type "volume"
  5. Tap or click Speaker icon
  6. Select Enhancements tab
2012-11-21T19:43:44+00:00
Hi Danieleyassu,
I hope this helps!
David
2012-11-01T22:56:05+00:00
2012-11-09T21:43:21+00:00
2014-03-30T23:40:07+00:00
Hi lix2k3
  1. Go to your desktop
  2. Click on control panel
  3. Go to Hardware and Sound
  4. Click on Sound
  6. Go to enhancements
Regards
Kevin N.
2013-08-14T18:31:26+00:00
2013-03-09T00:24:09+00:00
Hello MiguelVemba,
Best regards.
2013-01-08T22:01:52+00:00
Bricr
2013-01-02T15:06:17+00:00
Hi Boonie46.
Thanks!
2012-12-13T02:09:55+00:00
Hello mvb0351,
Rebecca_AA1
2012-11-29T00:30:25+00:00
Hello Troy,
267 additional answers
    2012-12-12T13:11:08+00:00
    Hello everyone,
    Sorry for the delayed response. I would like to know if you have tried what our MVP, David Scammell, had suggested and compared your own Surface against others at a Microsoft Store to see if its a fault in your Surface, or in general.
    I went to the store and employee there said it was a common complaint and that the volume was fairly low.  I am listening in a quiet room.  The volume at 100% is lower than expected.  Also, the sound gets muted occassionally - sometimes out of locked mode, sometimes when i use the touch cover trackpad.
    Is it possible that there is a software or firmware fix, or is this a device limitation that won't be addressed until version 2 comes out?
    Overall the Surface is a great hardware design, but the sound issue is a real flaw in my opinion.
    Thanks.
