2012-11-01T20:24:52+00:00
Surface | Other
2013-01-11T22:49:32+00:00
Hi NoBoundaries.
To select enhancements:
  2. Tap or click Search
  3. Type "volume"
  5. Tap or click Speaker icon
  6. Select Enhancements tab
2012-11-21T19:43:44+00:00
Hi Danieleyassu,
I hope this helps!
David
2012-11-01T22:56:05+00:00
2012-11-09T21:43:21+00:00
2014-03-30T23:40:07+00:00
Hi lix2k3
  1. Go to your desktop
  2. Click on control panel
  3. Go to Hardware and Sound
  4. Click on Sound
  6. Go to enhancements
Regards
Kevin N.
2013-08-14T18:31:26+00:00
2013-03-09T00:24:09+00:00
Hello MiguelVemba,
Best regards.
2013-01-08T22:01:52+00:00
Bricr
2013-01-02T15:06:17+00:00
Hi Boonie46.
Thanks!
2012-12-13T02:09:55+00:00
Hello mvb0351,
Rebecca_AA1
2012-11-29T00:30:25+00:00
Hello Troy,
267 additional answers
    2012-12-08T20:24:24+00:00
    I too agree that the sound level is quite bad. I don't think there is anyone here asking for it to be a whole room audio device but it should be somewhat louder. My wifes $200 kindle fire hd is considerably louder then my surface.
    I have no intention of taking it to be exchanged for the audio level as the problem is not with my model...but with all models. The surface is just quiet.
    Other than that I have had few issues with it. The need to go into desktop mode for ANYTHING was a very poor design process, there should never be a reason to go into desktop mode on the WinRT version period. Office should have been built in as a windows store app and all other features assessable through charms bar.
    I really like the surface but fix the sound level with a software update if possible...and fix the WIFI drops.
