2012-11-01T20:24:52+00:00
Surface | Other
2013-01-11T22:49:32+00:00
Hi NoBoundaries.
To select enhancements:
  2. Tap or click Search
  3. Type "volume"
  5. Tap or click Speaker icon
  6. Select Enhancements tab
2012-11-21T19:43:44+00:00
Hi Danieleyassu,
I hope this helps!
David
2012-11-01T22:56:05+00:00
2012-11-09T21:43:21+00:00
2014-03-30T23:40:07+00:00
Hi lix2k3
  1. Go to your desktop
  2. Click on control panel
  3. Go to Hardware and Sound
  4. Click on Sound
  6. Go to enhancements
Regards
Kevin N.
2013-08-14T18:31:26+00:00
2013-03-09T00:24:09+00:00
Hello MiguelVemba,
Best regards.
2013-01-08T22:01:52+00:00
Bricr
2013-01-02T15:06:17+00:00
Hi Boonie46.
Thanks!
2012-12-13T02:09:55+00:00
Hello mvb0351,
Rebecca_AA1
2012-11-29T00:30:25+00:00
Hello Troy,
267 additional answers
    2012-12-06T00:40:49+00:00
    If you are using your Surface in a noisy location such as Starbucks it would be highly recommended that you use Headphones or Earbuds so that you can enjoy the audio at a level that you can hear over the din and, at the same time, avoid bothering other patrons at the same time. While you want to be able to hear your music and/or movies, those around you do not, after all.
    First, I do not disagree with you.
    I always try to avoid bothering others and wish everyone yelling into to their cell phones also would be much more considerate. But that is a separate issue.
    The Starbucks example, yes an example, was meant to reflect how the maximum volume is very low. Maybe a better example in my case would be that I am unable to properly hear the Surface when I am ALONE in my own home without muting the TV.
    BTW, shouldn't the Surface software have the ability to make sounds audible at least to the mildly hearing impaired?
    I think it was a design tradeoff - The Surface is very thin so not much room for anything in the casing = Also notice there are no large speaker holes - just a small oval vent in the case on each side.  I know some other tablet, like Asus Transformer/Infinity, chose to have only one speaker rather than 2 like the surface has.  I believe at one point I read about a teardown of the surface and the speakers were very small.  Not trying to justify Microsoft's choice, but that had to be a factor.  As I said previously there are some audio enhancements that make it a bit louder and i honestly don't see the volume being an issue, as I dont see alot of people with with loud tablets in public places.  I think if you were sitting on your couch watching a movie the volume would be fine. Wit hthat said, I don't think that MS could make them any loud wit hsoftware tweaks due to the speaker sizes.
    The iPad is very thin, but the speakers are twice as loud...
