2012-11-01T20:24:52+00:00
Surface | Other
2013-01-11T22:49:32+00:00
Hi NoBoundaries.
To select enhancements:
  2. Tap or click Search
  3. Type "volume"
  5. Tap or click Speaker icon
  6. Select Enhancements tab
2012-11-21T19:43:44+00:00
Hi Danieleyassu,
I hope this helps!
David
2012-11-01T22:56:05+00:00
2012-11-09T21:43:21+00:00
2014-03-30T23:40:07+00:00
Hi lix2k3
  1. Go to your desktop
  2. Click on control panel
  3. Go to Hardware and Sound
  4. Click on Sound
  6. Go to enhancements
Regards
Kevin N.
2013-08-14T18:31:26+00:00
2013-03-09T00:24:09+00:00
Hello MiguelVemba,
Best regards.
2013-01-08T22:01:52+00:00
Bricr
2013-01-02T15:06:17+00:00
Hi Boonie46.
Thanks!
2012-12-13T02:09:55+00:00
Hello mvb0351,
Rebecca_AA1
2012-11-29T00:30:25+00:00
Hello Troy,
267 additional answers
    2012-11-30T15:05:11+00:00
    Hi ZacharyVelasquez,
    I'd have to suggest that there might be a possible hardware issue as I have no problem with my Surface tablet's sound. However, depending on how loud the TV is, the TV could be loud enough to drown out the sound on the tablet. In similar cases, I simply plug in my earbuds or headphones and everything is fine. I have also hooked up powered external speakers to my Surface RT tablet for extra "cranking" power for my music.
    However, I would like to note that on Thanksgiving, I used my Surface RT tablet to provide background music for our Family Thanksgiving Dinner and it worked perfectly.
    I hope this helps!
    David
