2012-11-01T20:24:52+00:00
Surface | Other
2013-01-11T22:49:32+00:00
Hi NoBoundaries.
To select enhancements:
  2. Tap or click Search
  3. Type "volume"
  5. Tap or click Speaker icon
  6. Select Enhancements tab
2012-11-21T19:43:44+00:00
Hi Danieleyassu,
I hope this helps!
David
2012-11-01T22:56:05+00:00
2012-11-09T21:43:21+00:00
2014-03-30T23:40:07+00:00
Hi lix2k3
  1. Go to your desktop
  2. Click on control panel
  3. Go to Hardware and Sound
  4. Click on Sound
  6. Go to enhancements
Regards
Kevin N.
2013-08-14T18:31:26+00:00
2013-03-09T00:24:09+00:00
Hello MiguelVemba,
Best regards.
2013-01-08T22:01:52+00:00
Bricr
2013-01-02T15:06:17+00:00
Hi Boonie46.
Thanks!
2012-12-13T02:09:55+00:00
Hello mvb0351,
Rebecca_AA1
2012-11-29T00:30:25+00:00
Hello Troy,
267 additional answers
  1. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2012-11-28T11:38:02+00:00
    I have been doing Consumer Camp "Streaming Your Media" demos at my local MS
    Store. I can tell you that the volume on the Surface units is way too low
    (compared to other consumer electronic devices).  My next demo is Friday. I will
    try more demo units, but in general either the speaker hardware is not up to the
    task or the software needs to be tweaked.
    Barb
    MVP - Windows Entertainment and Connected Home
    http://digitalmediaphile.com/
