2012-11-01T20:24:52+00:00
Surface | Other
2013-01-11T22:49:32+00:00
Hi NoBoundaries.
To select enhancements:
  2. Tap or click Search
  3. Type "volume"
  5. Tap or click Speaker icon
  6. Select Enhancements tab
2012-11-21T19:43:44+00:00
Hi Danieleyassu,
I hope this helps!
David
2012-11-01T22:56:05+00:00
2012-11-09T21:43:21+00:00
2014-03-30T23:40:07+00:00
Hi lix2k3
  1. Go to your desktop
  2. Click on control panel
  3. Go to Hardware and Sound
  4. Click on Sound
  6. Go to enhancements
Regards
Kevin N.
2013-08-14T18:31:26+00:00
2013-03-09T00:24:09+00:00
Hello MiguelVemba,
Best regards.
2013-01-08T22:01:52+00:00
Bricr
2013-01-02T15:06:17+00:00
Hi Boonie46.
Thanks!
2012-12-13T02:09:55+00:00
Hello mvb0351,
Rebecca_AA1
2012-11-29T00:30:25+00:00
Hello Troy,
267 additional answers
    2016-12-08T20:10:25+00:00
    I posted this suggestion a while back that solved my volume issue, but it was moved because this is the Surface RT section and mine is a Surface Pro 3. Anyway, it may or may not be applicable depending on your computer model, operating system, or version of Chrome you may or may not be running. So as they say...your results may vary.
    https://answers.microsoft.com/en-us/surface/forum/surfpro3-surfgetstart/surface-pro-3-increasing-streamed-media-volume/b31c9fc6-790d-41d8-8778-688396f270ab
