2012-11-01T20:24:52+00:00
Surface | Other
2013-01-11T22:49:32+00:00
Hi NoBoundaries.
To select enhancements:
  2. Tap or click Search
  3. Type "volume"
  5. Tap or click Speaker icon
  6. Select Enhancements tab
2012-11-21T19:43:44+00:00
Hi Danieleyassu,
I hope this helps!
David
2012-11-01T22:56:05+00:00
2012-11-09T21:43:21+00:00
2014-03-30T23:40:07+00:00
Hi lix2k3
  1. Go to your desktop
  2. Click on control panel
  3. Go to Hardware and Sound
  4. Click on Sound
  6. Go to enhancements
Regards
Kevin N.
2013-08-14T18:31:26+00:00
2013-03-09T00:24:09+00:00
Hello MiguelVemba,
Best regards.
2013-01-08T22:01:52+00:00
Bricr
2013-01-02T15:06:17+00:00
Hi Boonie46.
Thanks!
2012-12-13T02:09:55+00:00
Hello mvb0351,
Rebecca_AA1
2012-11-29T00:30:25+00:00
Hello Troy,
267 additional answers
    2013-12-29T21:41:23+00:00
    The speaker settings may be messed up with your surface... this can apply to all Windows devices.
    Swipe in from the right, and click on the search icon.
    Then type in the box "Sound" and click on the result highlighted below:
    This dialog will display:
    Note: some of your's will show different items than the one shown above...
    Click on selection that says "Speakers, NVIDIA Tegra Wave Device" and then click the properties button on the bottom.
    On the dialog that displays, click on the "Enhancements" tab
    Then check the box for "Loudness Equalization" This will noticeably increase the volume.
    Remember, when you watch videos (especially on streaming services like YouTube and Netflix) the volume can often vary based on the connection and the volume of the video that was published. Try watching a variety of youtube videos to see how the volume compares to an iPad. I have used both and honestly, the max volumes seem to be about the same.
    Hope this helps!
