2012-11-01T20:24:52+00:00
Surface | Other
2013-01-11T22:49:32+00:00
Hi NoBoundaries.
To select enhancements:
  2. Tap or click Search
  3. Type "volume"
  5. Tap or click Speaker icon
  6. Select Enhancements tab
2012-11-21T19:43:44+00:00
Hi Danieleyassu,
I hope this helps!
David
2012-11-01T22:56:05+00:00
2012-11-09T21:43:21+00:00
2014-03-30T23:40:07+00:00
Hi lix2k3
  1. Go to your desktop
  2. Click on control panel
  3. Go to Hardware and Sound
  4. Click on Sound
  6. Go to enhancements
Regards
Kevin N.
2013-08-14T18:31:26+00:00
2013-03-09T00:24:09+00:00
Hello MiguelVemba,
Best regards.
2013-01-08T22:01:52+00:00
Bricr
2013-01-02T15:06:17+00:00
Hi Boonie46.
Thanks!
2012-12-13T02:09:55+00:00
Hello mvb0351,
Rebecca_AA1
2012-11-29T00:30:25+00:00
Hello Troy,
267 additional answers
    2012-11-09T19:50:39+00:00
    My maximum volume level low on surface rt, is there a solution available?
    quote from: http://www.laptopmag.com/review/tablets/microsoft-surface-rt.aspx
    Audio
    When you carry the Surface with RT, you'll want to pack a pair of headphones. The small side-mounted speakers offer sound that's accurate, but way too quiet. Whether we were watching a video, playing a game or listening to music, the audio level was so low that, even at maximum volume, voices were barely audible in a quiet room. When we played the heavy metal song "Rock of Ages" from Slacker, the guitar and drums were not tinny at all, but a friend standing 5 feet away from us could not even make out the lyrics
