2012-11-01T20:24:52+00:00
Surface | Other
2013-01-11T22:49:32+00:00
Hi NoBoundaries.
To select enhancements:
  2. Tap or click Search
  3. Type "volume"
  5. Tap or click Speaker icon
  6. Select Enhancements tab
2012-11-21T19:43:44+00:00
Hi Danieleyassu,
I hope this helps!
David
2012-11-01T22:56:05+00:00
2012-11-09T21:43:21+00:00
2014-03-30T23:40:07+00:00
Hi lix2k3
  1. Go to your desktop
  2. Click on control panel
  3. Go to Hardware and Sound
  4. Click on Sound
  6. Go to enhancements
Regards
Kevin N.
2013-08-14T18:31:26+00:00
2013-03-09T00:24:09+00:00
Hello MiguelVemba,
Best regards.
2013-01-08T22:01:52+00:00
Bricr
2013-01-02T15:06:17+00:00
Hi Boonie46.
Thanks!
2012-12-13T02:09:55+00:00
Hello mvb0351,
Rebecca_AA1
2012-11-29T00:30:25+00:00
Hello Troy,
267 additional answers
    2013-05-16T23:03:49+00:00
    I have the same issues. I usually use the Surface RT in a quiet environment and therefore mostly use it on low volume (lower than 10 or even as low as 4 or 6 on some games). Since the last patch day the sound changes its volume itself during playback. First it is loud for a few seconds, then it gets quiet for another few seconds, then loud again ... like if there was some kind of audio normalization working in the background creating a slowly pulsating sound.
    The problem exists on any application. There is no problem when listening via headphones, although I have to say that the sound is much too loud on headphones. I always have to reduce the volume to a 2 or 4 points.
    Generally speaking, although I understand people saying the Surface RT speakers weren't loud enough, I really liked it that way because it was quite natural and high quality without the typical distortion of most other mobile devices. So there should be at least a setting where you can activate or deactivate the volume boost so you can choose whether you prefer good sound quality or loudness.
