2012-11-01T20:24:52+00:00
Surface | Other
2013-01-11T22:49:32+00:00
Hi NoBoundaries.
To select enhancements:
  2. Tap or click Search
  3. Type "volume"
  5. Tap or click Speaker icon
  6. Select Enhancements tab
2012-11-21T19:43:44+00:00
Hi Danieleyassu,
I hope this helps!
David
2012-11-01T22:56:05+00:00
2012-11-09T21:43:21+00:00
2014-03-30T23:40:07+00:00
Hi lix2k3
  1. Go to your desktop
  2. Click on control panel
  3. Go to Hardware and Sound
  4. Click on Sound
  6. Go to enhancements
Regards
Kevin N.
2013-08-14T18:31:26+00:00
2013-03-09T00:24:09+00:00
Hello MiguelVemba,
Best regards.
2013-01-08T22:01:52+00:00
Bricr
2013-01-02T15:06:17+00:00
Hi Boonie46.
Thanks!
2012-12-13T02:09:55+00:00
Hello mvb0351,
Rebecca_AA1
2012-11-29T00:30:25+00:00
Hello Troy,
267 additional answers
    2013-04-14T16:27:23+00:00
    I was using Skype on Christmas to talk to my brother and mother and everyone in the room had to be quiet and the tv had to be off so that we could hear what was being said by them. Audio is very low which makes it difficult to hear. Headphones work great, but that sort of defeats the purpose of using Skype for family video calls.
    Thanks.
    Not sure if this is recent or something done in Skype, but audio on Skype is good to almost loud...other apps, not even close to acceptable in a quiet room. So what gives?
    In the other hand I see the pop-out incoming Skype call, which once clicked goes to Skype, but never is a call answerable, so you have to actually call the person or wait for them to call back or often play competing Skype calls game with them.
