2012-11-01T20:24:52+00:00
Surface | Other
2013-01-11T22:49:32+00:00
Hi NoBoundaries.
To select enhancements:
  2. Tap or click Search
  3. Type "volume"
  5. Tap or click Speaker icon
  6. Select Enhancements tab
2012-11-21T19:43:44+00:00
Hi Danieleyassu,
I hope this helps!
David
2012-11-01T22:56:05+00:00
2012-11-09T21:43:21+00:00
2014-03-30T23:40:07+00:00
Hi lix2k3
  1. Go to your desktop
  2. Click on control panel
  3. Go to Hardware and Sound
  4. Click on Sound
  6. Go to enhancements
Regards
Kevin N.
2013-08-14T18:31:26+00:00
2013-03-09T00:24:09+00:00
Hello MiguelVemba,
Best regards.
2013-01-08T22:01:52+00:00
Bricr
2013-01-02T15:06:17+00:00
Hi Boonie46.
Thanks!
2012-12-13T02:09:55+00:00
Hello mvb0351,
Rebecca_AA1
2012-11-29T00:30:25+00:00
Hello Troy,
267 additional answers
    2013-04-14T14:52:27+00:00
    With all that being said, the Surface has extremely low on speaker volume when compared to ipads and other competing tablets.  I tried to play Netflix cartoons for my daughter to watch and it just wasn't fair to expect her to hear anything.  I could barely make out anything and the room was not very noisy at all.  Of course it wasn't dead silence, but that shouldn't be necessary for sufficient clarity.  The fact is, the speakers are ridiculously low compared to any other competing tablet.  The sad thing is, my Nokia Lumia 900 has a louder speaker volume than the Surface.  Something is wrong with that picture.  It's low to the point of being a critical hardware failure, and if it wasn't for some other good features of the tablet, I'd return it just off of the speaker volume alone.
    No it definitely is a two fold flaw, the speakers seem a bit small (as the poster above points out even a smart phones speaker is louder), but I think the most critical flaw is something software wise (which means they and should fix it ASAP or suffer loosing any market share they are gaining. The reason why I say it is software is because you see it on things like certain programs (like IE10 metro), but some things not. Heck the SoftTouch keyboard clicks are louder than music on Pandora. It is just like the speaker phone on both my HTC Radar 4G and now HTC Windows 8X...it makes me wonder how much is hardware because there is definitely a software problem (partner with some pros and get this fixed ASAP, it is important regardless of what you guys have decided internal to MS).
    It gets better on headphones, but not much. I hate to try listening on a plane without a good set of noise cancelling headphones...because try will turn into tried and failed. Starting to think I should have just gone with one of the other Windows 8 tablet hybrids...which may be why MS has Surface mixed in the pile with the rest of them on their Win8 site vs. being featured.
