2012-11-01T20:24:52+00:00
Surface | Other
2013-01-11T22:49:32+00:00
Hi NoBoundaries.
To select enhancements:
  2. Tap or click Search
  3. Type "volume"
  5. Tap or click Speaker icon
  6. Select Enhancements tab
2012-11-21T19:43:44+00:00
Hi Danieleyassu,
I hope this helps!
David
2012-11-01T22:56:05+00:00
2012-11-09T21:43:21+00:00
2014-03-30T23:40:07+00:00
Hi lix2k3
  1. Go to your desktop
  2. Click on control panel
  3. Go to Hardware and Sound
  4. Click on Sound
  6. Go to enhancements
Regards
Kevin N.
2013-08-14T18:31:26+00:00
2013-03-09T00:24:09+00:00
Hello MiguelVemba,
Best regards.
2013-01-08T22:01:52+00:00
Bricr
2013-01-02T15:06:17+00:00
Hi Boonie46.
Thanks!
2012-12-13T02:09:55+00:00
Hello mvb0351,
Rebecca_AA1
2012-11-29T00:30:25+00:00
Hello Troy,
267 additional answers
    2013-04-08T16:06:41+00:00
    In a quiet room I have no problems with the Surface volume, the other day I kicked back the stand, placed the surface by the bed side stand and played Xbox Music and it was fine even with the volume setting only half way. In a busy room you may have to crank it up a lot higher but honestly plug in a pair of quality headphones and its great, almost too loud I had to reduce the volume. Given how thin and small the speakers are its a trade off, but still better than the iPad's speakers. You could also get yourself some quality Bluetooth speakers can stream to that instead.
    The sound quality is better than the iPad, but the volume is louder on the iPad...with exception of when headphones or external speakers are used. The Surface obviously has the power for incredible sound, but not much volume for the internal speakers.
