2012-11-01T20:24:52+00:00
Surface | Other
2013-01-11T22:49:32+00:00
Hi NoBoundaries.
To select enhancements:
  2. Tap or click Search
  3. Type "volume"
  5. Tap or click Speaker icon
  6. Select Enhancements tab
2012-11-21T19:43:44+00:00
Hi Danieleyassu,
I hope this helps!
David
2012-11-01T22:56:05+00:00
2012-11-09T21:43:21+00:00
2014-03-30T23:40:07+00:00
Hi lix2k3
  1. Go to your desktop
  2. Click on control panel
  3. Go to Hardware and Sound
  4. Click on Sound
  6. Go to enhancements
Regards
Kevin N.
2013-08-14T18:31:26+00:00
2013-03-09T00:24:09+00:00
Hello MiguelVemba,
Best regards.
2013-01-08T22:01:52+00:00
Bricr
2013-01-02T15:06:17+00:00
Hi Boonie46.
Thanks!
2012-12-13T02:09:55+00:00
Hello mvb0351,
Rebecca_AA1
2012-11-29T00:30:25+00:00
Hello Troy,
267 additional answers
    2013-04-08T15:58:35+00:00
    You guys can talk about trade offs or whatever other excuses you want to give for the utter useless sound on the Surface, but the fact is very simply. The maximum volume is far too low for any device. My kids iPod speakers are way louder.
    I cannot hear what it being said on my Surface. Well, if I put my ear to it, I can. Yes, it is that bad.
    Even though I love the Surface I agree that the speakers are ridiculously low. The volume rocker doesn't seem to serve a purpose with the internal speakers since the only setting even mildly audible is the highest one. With my air conditioning or fan going I cant hear it. My iPad is audible in these same conditions. My BlackBerry playbook is so loud I only have to turn it up halfway to hear it in these same conditions. Watching a movie on the Surface had to be done with ear phones in most situations. The only place in my home where it is really audible is in the restroom.
    I did figure out that if I hold the Surface cupping my hands around the speakers and forcing most of the sound to the front, redirects the sound enough to make it a bit easier to hear. Not really a solution but it helps if your on a couch or lying in bed.
