2012-11-01T20:24:52+00:00
Surface | Other
2013-01-11T22:49:32+00:00
Hi NoBoundaries.
To select enhancements:
  2. Tap or click Search
  3. Type "volume"
  5. Tap or click Speaker icon
  6. Select Enhancements tab
2012-11-21T19:43:44+00:00
Hi Danieleyassu,
I hope this helps!
David
2012-11-01T22:56:05+00:00
2012-11-09T21:43:21+00:00
2014-03-30T23:40:07+00:00
Hi lix2k3
  1. Go to your desktop
  2. Click on control panel
  3. Go to Hardware and Sound
  4. Click on Sound
  6. Go to enhancements
Regards
Kevin N.
2013-08-14T18:31:26+00:00
2013-03-09T00:24:09+00:00
Hello MiguelVemba,
Best regards.
2013-01-08T22:01:52+00:00
Bricr
2013-01-02T15:06:17+00:00
Hi Boonie46.
Thanks!
2012-12-13T02:09:55+00:00
Hello mvb0351,
Rebecca_AA1
2012-11-29T00:30:25+00:00
Hello Troy,
267 additional answers
    2013-03-06T21:17:50+00:00
    Hello MiguelVemba,
    You can try this: Go to Control Panel, then Sound, then click on Speakers, then Properties, then Enhancements and check Loudness Equalisation and Virtual Surround too, if you wish. Apply changes.
    Please let us know if this increases the volume for your Surface.
