2012-11-01T20:24:52+00:00
Surface | Other
2013-01-11T22:49:32+00:00
Hi NoBoundaries.
To select enhancements:
  2. Tap or click Search
  3. Type "volume"
  5. Tap or click Speaker icon
  6. Select Enhancements tab
2012-11-21T19:43:44+00:00
Hi Danieleyassu,
I hope this helps!
David
2012-11-01T22:56:05+00:00
2012-11-09T21:43:21+00:00
2014-03-30T23:40:07+00:00
Hi lix2k3
  1. Go to your desktop
  2. Click on control panel
  3. Go to Hardware and Sound
  4. Click on Sound
  6. Go to enhancements
Regards
Kevin N.
2013-08-14T18:31:26+00:00
2013-03-09T00:24:09+00:00
Hello MiguelVemba,
Best regards.
2013-01-08T22:01:52+00:00
Bricr
2013-01-02T15:06:17+00:00
Hi Boonie46.
Thanks!
2012-12-13T02:09:55+00:00
Hello mvb0351,
Rebecca_AA1
2012-11-29T00:30:25+00:00
Hello Troy,
267 additional answers
    2013-01-13T22:40:51+00:00
    I've had my surface for a whole and I've had this problem for a while. I'm sure that it is just a hardware problem, but the loudness of the speakers is extremely poor. In a normal sized room with someone watching the tv and myself playing on my surface I can hear sound coming from it but it is rather hard even when there isn't much going on in the room. My cell phone has louder speakers than the surface does.
    I'm rather disappointed in the sound quality that comes form the device.
    Hey there,
    Swipe the charms and search for 'control panel,' find and touch 'sound.' Double tap 'Speakers,' (in the window, not one of the tabs across the top.) Touch the enhancements tab, and check off 'Loudness Equalization.' Touch 'apply' and then touch 'OK.' This will give a significant boost to your speaker volume output. You can also mess with the other enhancements and see of that helps you out as well.
    Take care,
    Neither loudness equalization or any of the other enhancements were checked - but - I checked loudness equalisation on, then off, then apply.
    Bizarre - that did make a noticeable difference.
