2012-11-01T20:24:52+00:00
Surface | Other
2013-01-11T22:49:32+00:00
Hi NoBoundaries.
To select enhancements:
  2. Tap or click Search
  3. Type "volume"
  5. Tap or click Speaker icon
  6. Select Enhancements tab
2012-11-21T19:43:44+00:00
Hi Danieleyassu,
I hope this helps!
David
2012-11-01T22:56:05+00:00
2012-11-09T21:43:21+00:00
2014-03-30T23:40:07+00:00
Hi lix2k3
  1. Go to your desktop
  2. Click on control panel
  3. Go to Hardware and Sound
  4. Click on Sound
  6. Go to enhancements
Regards
Kevin N.
2013-08-14T18:31:26+00:00
2013-03-09T00:24:09+00:00
Hello MiguelVemba,
Best regards.
2013-01-08T22:01:52+00:00
Bricr
2013-01-02T15:06:17+00:00
Hi Boonie46.
Thanks!
2012-12-13T02:09:55+00:00
Hello mvb0351,
Rebecca_AA1
2012-11-29T00:30:25+00:00
Hello Troy,
267 additional answers
    2013-12-20T16:59:03+00:00
    My enhancement tab only has a checkbox for turning on enhancements. Why can't I get the controls?
    Thx
