2012-11-01T20:24:52+00:00
Surface | Other
2013-01-11T22:49:32+00:00
Hi NoBoundaries.
To select enhancements:
  2. Tap or click Search
  3. Type "volume"
  5. Tap or click Speaker icon
  6. Select Enhancements tab
2012-11-21T19:43:44+00:00
Hi Danieleyassu,
I hope this helps!
David
2012-11-01T22:56:05+00:00
2012-11-09T21:43:21+00:00
2014-03-30T23:40:07+00:00
Hi lix2k3
  1. Go to your desktop
  2. Click on control panel
  3. Go to Hardware and Sound
  4. Click on Sound
  6. Go to enhancements
Regards
Kevin N.
2013-08-14T18:31:26+00:00
2013-03-09T00:24:09+00:00
Hello MiguelVemba,
Best regards.
2013-01-08T22:01:52+00:00
Bricr
2013-01-02T15:06:17+00:00
Hi Boonie46.
Thanks!
2012-12-13T02:09:55+00:00
Hello mvb0351,
Rebecca_AA1
2012-11-29T00:30:25+00:00
Hello Troy,
267 additional answers
    2012-11-16T18:47:59+00:00
    If you are using your Surface in a noisy location such as Starbucks it would be highly recommended that you use Headphones or Earbuds so that you can enjoy the audio at a level that you can hear over the din and, at the same time, avoid bothering other patrons at the same time. While you want to be able to hear your music and/or movies, those around you do not, after all.
    First, I do not disagree with you.
    I always try to avoid bothering others and wish everyone yelling into to their cell phones also would be much more considerate. But that is a separate issue.
    The Starbucks example, yes an example, was meant to reflect how the maximum volume is very low. Maybe a better example in my case would be that I am unable to properly hear the Surface when I am ALONE in my own home without muting the TV.
    BTW, shouldn't the Surface software have the ability to make sounds audible at least to the mildly hearing impaired?
