Hello all
Surface Pro 3 devices use a specially treated magnesium alloy case designed to help reduce weight, improve battery performance and because the treatment allows the case to be slightly malleable, improve durability in use. As a side effect of this treatment,
devices can acquire a slight curvature. This curvature only occurs during the treatment process and does not change after manufacturing.
Our manufacturing process adheres to a strict specification for the maximum allowed curvature of the device and we routinely test newly manufactured devices to insure that specification is being met. This curvature does not impact functionality or usability
of the device in any way. Microsoft is always looking for ways to improve the aesthetics and quality of our devices and we greatly value the feedback that we have received from our customers.
Best regards
I beg to differ. While warping at the top may not impact functionality, the warping on my device has occurred at the bottom, right where the type cover connects. Although the bending is minute, it has affected the cover to connect properly at times, forcing
me to either push it in properly or reconnect.
I have contacted support and they will be picking up my unit tomorrow. Hopefully a replacement will be sent ASAP as the SP3 is an essential part of my work toolset.
I have another unit of SP3 and am glad to say that the type cover works perfectly with it due to the absence of any warping.
