There's an extended discussion in this thread:
Can Surface pro run dual external monitors?
With the ports configuration and specs of the announced Surface Pro, can one run dual external monitors? By that I mean connecting two external monitors, one for primary display and one for extended display. Irrelevant what shows on the actual Surface screen.
This is the current configuration I have for my heavy laptop (with docking station) and want to recreate it if I swap to the cool Surface Pro.
I don't mind buying some port replicators, as long as the set-up works seamlessly once connected. I saw some other threads and no docking station is planned by Microsoft at this stage
Thanks for input
Surface | Surface Pro | USB-C
Greetings ManlioV,
That's a great question. Because the Surface Pro is running Windows 8, you could get a USB port hub and USB video cards and the Surface Pro would be able to install the drivers so you could hook up multiple monitors that way.
Hope that helps.
55 additional answers
2013-03-08T16:20:27+00:00 I was able to watch on Netflix or on Xbox video with no problem. I took the video that was playing and moved it to the other two monitors I have hooked up. Didnt seem to be issues.
Someone on this thread was complaining about displaylink drivers. The Targus I bought had new 2013 drivers for Win8 so maybe the problem he was having is fixed. I havent had any problems.
2013-03-08T18:14:23+00:00 And if you disconnect from the dock, you have no issues watching videos in the Xbox or any other app as well?
The person above is using a DisplayLink docking station rather than Targus.
2013-03-08T20:13:08+00:00 This is a problem with the XBOX video app its a pretty weak/**** app your right. There are a lot better apps to play the videos you have purchased through the Xbox live if thats what your asking. Using the XBOX live app you get an error when accessing content. The xbox video player must have a problem with video driver/codec or whatever. But like I said use a different player its not a very good app anyway.
Cant Play
Cant play. Make sure your computers sound and video cards are working and have the latest drivers, then try again
more info
0xc00d11d1
You might start another thread as this was a discussion about dual monitors...
