Screen flicker and ghosting
2017-06-21T11:24:18+00:00
My surface pro 4 developed a horizontal line across the top of the screen, and then ghsot windows appeared of closed boxes during use, to the extent where the screen became unreadable and a restart was needed.
My device warranty expired in April, and i understand that MS doesn't do anything except replace the device if there's an issue, so my question is, without a warranty, what is there to do?  I can't believe that after a year, a device that costs as much as a top-end laptop, brakes and has to be thrown away.
Anyone had any similar issues and found solutions?
HELP!!
    2018-10-09T19:03:24+00:00
    I am having the same trouble with the Surface Pro LTE.  What is the process of getting the tablet replaced?
