External screen flicker on Surface Book 2 using USB-C to HDMI adapter.
I had no issues using my SB 2, USB-C to HDMI adapter, and DELL Ultrasharp 3818DW monitor over the last 6 months or so ... until this morning when the highly annoying frequent flickering started.
After unsuccessfully trying to fix the problem with a different HDMI cable and monitor I started reading this forum and am happy to report that it helped me FIX my problem. As others have reported before me, the fix is or at least can be simple.
I shutdown my SB, disconnected all pheripherals, started the SB back up, un-docked the screen, cleaned the screen connections and USB-C port using an air dust blower (for cameras), and re-docked the screen to the keyboard. I then reconnected the monitor and other pheripherals and was very happy to discover the problem was gone and I could get to work--after sharing my experience on this forum.
Thanks to all of you that helped me along!
