Is Audio Supported Over HDMI?
2012-11-01T01:31:37+00:00
I connected my Surface via HDMI to watch some movies on the home theater system, but I'm only hearing sound through the Surface speakers. How do I get audio to go through HDMI so that I can use my nice home theater sound system?
Surface | Other
2015-05-18T19:38:24+00:00
Hi all.
I found probably a solution. When I connected the HDMI I only heard the sound in the surface and at the sound devices box the HDMI option won't appear, so I get in into Device Manager and Right click on my Surface and Scan for HW changes, then the sound starts to listen on the Home Theater. I expect this probably works in most of cases like me.
Regards.
2014-02-05T22:28:27+00:00
Greetings all,
Please contact the manufacturer of you television for furthers support and possible firmware updates.  This feature works with other TVs.
2017-01-21T11:11:37+00:00
Use the Sound applet in control panel to check what audio devices are installed. If you have a choice make sure the right one is selected.
With 11 pages on this thread and it is already answered few are going to see your question and have you read it through and looked at the possible solutions? If you have then it might be better to start your own question.
Detail what you have tried and what your hardware is, with laptops because everything is on the motherboard getting audio onto the HDMI is normally inbuilt but with desktops it could be different. Even with a desktop if you are using an integrated HDMI/sound card then that is the same as a laptop but if you have a discrete graphics/sound interface then that requires different settings.
106 additional answers
    2017-02-27T04:39:15+00:00
    The above directions work.  Just make sure you are logged in as an Administrator!
    2017-04-07T00:59:04+00:00
    There is no reason to contact the tv manufacturer i also have this problem no matter what tv i hook it up to. Iv only got it to work one time i found it disabled it worked for one day. The problem lies with the OS and for them to look into it you have to pay them, thats right you buy there product that dont work and they want you to pay them to fix it sounds like a scam to me. Just like when i watch netflix as soon as i switch it to full screen the surface pro 4 i have then crashes nothing but junk i suggest switching to apple product less problems and they will fix the problems for free
