Is Audio Supported Over HDMI?
2012-11-01T01:31:37+00:00
I connected my Surface via HDMI to watch some movies on the home theater system, but I'm only hearing sound through the Surface speakers. How do I get audio to go through HDMI so that I can use my nice home theater sound system?
Surface | Other
2015-05-18T19:38:24+00:00
Hi all.
I found probably a solution. When I connected the HDMI I only heard the sound in the surface and at the sound devices box the HDMI option won't appear, so I get in into Device Manager and Right click on my Surface and Scan for HW changes, then the sound starts to listen on the Home Theater. I expect this probably works in most of cases like me.
Regards.
2014-02-05T22:28:27+00:00
Greetings all,
Please contact the manufacturer of you television for furthers support and possible firmware updates.  This feature works with other TVs.
2017-01-21T11:11:37+00:00
Use the Sound applet in control panel to check what audio devices are installed. If you have a choice make sure the right one is selected.
With 11 pages on this thread and it is already answered few are going to see your question and have you read it through and looked at the possible solutions? If you have then it might be better to start your own question.
Detail what you have tried and what your hardware is, with laptops because everything is on the motherboard getting audio onto the HDMI is normally inbuilt but with desktops it could be different. Even with a desktop if you are using an integrated HDMI/sound card then that is the same as a laptop but if you have a discrete graphics/sound interface then that requires different settings.
106 additional answers
    2014-04-19T19:57:06+00:00
    Yes. Same problem with Vizio. It's more frustrating that I got it working (look back at my old posts) and then it stopped working.
    90% sure it is a driver issue / device recognition issue / windows rt software issue.
    Someone rich should donate 100 different styles of Vizio TVs so that the research team at Microsoft can test the surfaces on them to see how frustrating this bug is.
    2014-07-28T17:18:35+00:00
    Anyone found a solution? I have recently encountered the exact same behavior described here. HDMI port used to work for a 2nd display but now no longer receives the signal. Rebooting, windows + P, cable wiggeling, etc does not fix the problem. it's like the surface just disabled the capability. I really want this back since this is my primary machine atm, and I need to work off of a bigger screen than this.
