Is Audio Supported Over HDMI?
2012-11-01T01:31:37+00:00
I connected my Surface via HDMI to watch some movies on the home theater system, but I'm only hearing sound through the Surface speakers. How do I get audio to go through HDMI so that I can use my nice home theater sound system?
Surface | Other
2015-05-18T19:38:24+00:00
Hi all.
I found probably a solution. When I connected the HDMI I only heard the sound in the surface and at the sound devices box the HDMI option won't appear, so I get in into Device Manager and Right click on my Surface and Scan for HW changes, then the sound starts to listen on the Home Theater. I expect this probably works in most of cases like me.
Regards.
2014-02-05T22:28:27+00:00
Greetings all,
Please contact the manufacturer of you television for furthers support and possible firmware updates.  This feature works with other TVs.
2017-01-21T11:11:37+00:00
Use the Sound applet in control panel to check what audio devices are installed. If you have a choice make sure the right one is selected.
With 11 pages on this thread and it is already answered few are going to see your question and have you read it through and looked at the possible solutions? If you have then it might be better to start your own question.
Detail what you have tried and what your hardware is, with laptops because everything is on the motherboard getting audio onto the HDMI is normally inbuilt but with desktops it could be different. Even with a desktop if you are using an integrated HDMI/sound card then that is the same as a laptop but if you have a discrete graphics/sound interface then that requires different settings.
106 additional answers
    2014-01-28T03:26:12+00:00
    Ya I've tried that with no luck. Did the updates, constant plug/unplug, disable/enable drivers, but nothing seems to work. Remember anything specific? Thanks
    2014-02-01T20:42:01+00:00
    So any headway on this? Great some just have cabling issues, but it's not everyone, and it seems it's post the 8.1 update. So something has changed. Have even seen others pick up the new "refurbs" from MS's refurb reseller or whatever you want to call them. And they too are having the audio problem. So MS broke something with the updates. If you're going to dump product into the market, you should at least have basic things like HDMI out working properly.
    I don't put credence into "it's a 1st gen product". These are slated as premium devices and pretty much live up to that claim as anyone who handles one will admit to. Petty annoyances like this can really ruin a user's experience and not put a lot of faith into upgrading to its successor. Makes a Venue 11 Pro a better prospect as the days pass.
