Is Audio Supported Over HDMI?
2012-11-01T01:31:37+00:00
I connected my Surface via HDMI to watch some movies on the home theater system, but I'm only hearing sound through the Surface speakers. How do I get audio to go through HDMI so that I can use my nice home theater sound system?
Surface | Other
2015-05-18T19:38:24+00:00
Hi all.
I found probably a solution. When I connected the HDMI I only heard the sound in the surface and at the sound devices box the HDMI option won't appear, so I get in into Device Manager and Right click on my Surface and Scan for HW changes, then the sound starts to listen on the Home Theater. I expect this probably works in most of cases like me.
Regards.
2014-02-05T22:28:27+00:00
Greetings all,
Please contact the manufacturer of you television for furthers support and possible firmware updates.  This feature works with other TVs.
2017-01-21T11:11:37+00:00
Use the Sound applet in control panel to check what audio devices are installed. If you have a choice make sure the right one is selected.
With 11 pages on this thread and it is already answered few are going to see your question and have you read it through and looked at the possible solutions? If you have then it might be better to start your own question.
Detail what you have tried and what your hardware is, with laptops because everything is on the motherboard getting audio onto the HDMI is normally inbuilt but with desktops it could be different. Even with a desktop if you are using an integrated HDMI/sound card then that is the same as a laptop but if you have a discrete graphics/sound interface then that requires different settings.
106 additional answers
    2013-09-05T02:21:11+00:00
    i'm having issues with my LG 47LG50 tv.  I only get video, no audio.  I did get both audio and video to work on my much older Olevia tv so its not the cable.  When I plug the cable into the port, the lg tv disappears from the list of available sound sources and then when I unplug it, it reappears.
    2013-09-08T05:00:30+00:00
    I just purchased a Surface RT and also have the disappearing HD Sound device immediately when plugging in the Microsoft HDMI adapter cable to a 4 year old Visio LCD and 2 year old Visio LED.  This  problem has been reported for 10 months and I don't see a solution.  What progress is being made? This was a big selling point.  This doesn't appear to be a problem that is difficult to duplicate.   I did fully rebuild the Surface and that didn't help.  A laptop has no problem playing sound through HDMI to the same TVs.   Thanks for info.
