Is Audio Supported Over HDMI?
2012-11-01T01:31:37+00:00
I connected my Surface via HDMI to watch some movies on the home theater system, but I'm only hearing sound through the Surface speakers. How do I get audio to go through HDMI so that I can use my nice home theater sound system?
Surface | Other
2015-05-18T19:38:24+00:00
Hi all.
I found probably a solution. When I connected the HDMI I only heard the sound in the surface and at the sound devices box the HDMI option won't appear, so I get in into Device Manager and Right click on my Surface and Scan for HW changes, then the sound starts to listen on the Home Theater. I expect this probably works in most of cases like me.
Regards.
2014-02-05T22:28:27+00:00
Greetings all,
Please contact the manufacturer of you television for furthers support and possible firmware updates.  This feature works with other TVs.
2017-01-21T11:11:37+00:00
Use the Sound applet in control panel to check what audio devices are installed. If you have a choice make sure the right one is selected.
With 11 pages on this thread and it is already answered few are going to see your question and have you read it through and looked at the possible solutions? If you have then it might be better to start your own question.
Detail what you have tried and what your hardware is, with laptops because everything is on the motherboard getting audio onto the HDMI is normally inbuilt but with desktops it could be different. Even with a desktop if you are using an integrated HDMI/sound card then that is the same as a laptop but if you have a discrete graphics/sound interface then that requires different settings.
106 additional answers
    2012-11-07T04:46:32+00:00
    Greetings,
    We are aware of the issue and investigating the cause.
    Timothy and Jeremy, I don't expect you to have one, but if you have an Aux cable, can you plug that into your Surface and a speaker and see if the Surface plays to it automatically, or if you need to go into the Volume Control Panel and make the change.
    Also, if your PC monitor supports HDMI, can you replicate the issue to that as well as your TV ?
    2012-11-09T05:08:29+00:00
    I just got the Surface, and there is no audio output with HDMI. When can we expect to have it fix? As the speaker are very weak on the surface, this could be areal deal breaker.
    Other than that it's a cool gadget.
